11-01-2019 08:28 PM
I have updated the RV325 from the 1.3 firmware to RV32X_v1.5.1.05_20191001-code, I reset the router to default before the update and I tried to restart it multiple times
Now I cannot access the router through the 192.168.1.1, I got the below picture. So what can I do?
06-02-2020 01:05 AM
First of all, many thanks to JOHNCHERRY19837.
Indeed, this method will bring the router back to life.
My problem with RV320 (firmware: v1.5.1.05) was the result of the following actions: I set up OpenVPN and had problems adding more than 1 user. During various attempts, I accidentally changed the router's own certificate. After that I could no longer log in to the router via GUI (error: 502 Bad Gateway). I could still get to it via SSH but this router only has 3 CLI commands. You can't set a lot with these commands.
I tried to restore the factory settings (RESET button pressed for 10 seconds when turning on the router) but it did not work.
I did it as follows (according to the link provided by you: https://www.paladin.technology/tech/73-cisco-rv325-firmware-update-via-tftp.html):
1. I activated tftp in Windows 10 Pro, e.g. according to the description: https://www.thewindowsclub.com/enable-tftp-windows-10/
I checked that the tftp ... command works from the command window
2. I changed the computer's IP address to static: 192.168.1.100, M: 255.255.255.0, G: 192.168.1.1
3. I have only connected a PC to the router to the LAN1 port
4. downloaded from the Cisco website and placed in the directory: C: \ x_tmp firmware files in versions: RV320_FW_v1.0.2.03.bin ... RV32X_v1.5.1.05_20191001-code.bin
5. I turned on the router with the RESET button pressed and after about 10 seconds I run the command from the command window:
tftp -i 192.168.1.1 put C: \ x_pom \ RV320_FW_v1.0.2.03.bin
after that you have to wait until the file is copied into the router and the router will restart
ATTENTION: during the first attempts I uploaded the firmware in the latest versions: 1.5.1.05, 1.4.2.22 but it did not bring any improvement (the error continued: 502 Bad Gateway).
It was only after downloading the firmware in the oldest version available, i.e. 1.0.2.03, that it was possible to log into the router again (usr / pass: cisco / cisco) through the browser.
6. After that I activated the option: System management / Factory default / Factory default including certificates
7. I finally uploaded the latest firmware (1.5.1.05) from the GUI options
I hope these tips help others bring their RV320 / 325 back to life.
Best wishes
06-17-2020 07:16 AM - edited 06-17-2020 07:17 AM
Same Problem. The directions at this thread solved my problem:
Also, I noticed the 1.5xx fw seems to have been pulled or I just missed it on the support site. My cuirrent fw is 1.5.1.05. I do see a new firmware as of today 1.5.1.11 maybe it fixed the problem, but you may still need the fix to get into the unit to do the upgrade.
11-28-2020 06:27 AM
11-28-2020 10:03 AM
So it's the last known good version to fix the issue, good to know, Hope SMB TAC can note this and fix.
