RV325 Login Issue After Upgrading to 1.4.2.15
natesomers
I am receiving a "403 Forbidden" error after upgrading my RV325 from firmware 1.3.2.02 to 1.4.2.15. It happens when I navigate to the admin web interface and enter the correct credentials to login. I have tried power cycling the router without success. The full error is:
Forbidden
You don't have permission to access /cgi-bin/ssi.cgi on this server.
50 Replies 50
Well, waiting impatiently for an update to 1.4 firmware.
Update to the previous post.   I updated to the Inter VLAN routing to enabled then disabled the option and was able to login to the router.  After rebooting the router, I can no longer login to the router. This is a major issue since I rolled out the firmware update to production environments.  When will an update to the firmware be available to correct this issue?
Hi Gregu,
I too encountered this issue. On mine though, I had intervlan routing enabled for VLAN 1 tagged-no dhcp,10 untagged w/dhcp.  Having a VLAN 10 dhcp address, I got that Forbidden message. I was about to reset it when I came across your post. I set a static from VLAN 1 and I was able log in.  I disabled and reenabled intervlan routing feature and I was able to log in from either VLAN. Thanks for the heads up!
It was helpful to change password in User Management. FW 1.4.2.15. The problem is gone, I hope.
Try to upgrade FW to 1.4.2.17 later and reply here
FW 1.4.2.17 is the worst of the series, I highly suggest to not use it on production units.
yep. problem persist (forbidden access while using more than 1 vlan). this
router should not be used in a production site.
fordos.a
It seems to me, that CISCO does not care about this error.
Looking to the previous updates, seems that a FW update comes in 6 months.
Hope this comes early.
I myself solved all the problems by going back to version 1.3.
I cannot use version 1.3. It only allows 2 concurrent client easy vpn connections. I would have to revert back to 1.2.1.14
I have the same problem, after upgrade i lost connection to the router and because of this lost my job Who will compensate it for me?????
As I see there is no option to recovery because RV325 have no console port, factory reset - useless
Agrree !!!
arne.dahlman
Same problem on all browsers, I belive.
I managed to login to router using a VLAN1-port.
Then after that I could login using other VLANs as usual.
But after reebooting router I need to again login using a VLAN1-port once, then everything is working again.
Well, I think Cisco is doing everything in their power to convince us that this company is becoming just a bad joke.
After impatiently waiting for a firmware upgrade, I tried today to perform it with the “new firmware”, 1.4.2.17. And, surprise, just have a look at my attachment: “Bad upgrade file. Please input a correct file. Bla, bla”.
Well, I was already convinced that this RV320 is nothing but a piece of junk. Now, I am more than ever convinced that Cisco, as a company, is becoming, day after day, exactly the same.
Ha, Ha, another bad joke. Just look to my attached capture. Did you ever saw this on a fairly purchased equipment?
Firmware 1.4.2.17 was just released for the RV320. The release note has one resolved issue:
CSCvg42801   RV32x router has two unintended 'open' TCP ports after a firmware upgrade to v1.4.2.15.
I applied this and lost web access, again encountering the forbidden error referenced above after router reboot. Because this happened before, I set myself up a port on the router for VLAN1 with DHCP so I could just plug directly into that when I needed to. I was able to login then. This time, changing the admin password didn't resolve the issue.
What did resolve the issue for me this time was going into Port Management-->VLAN Membership, then selecting all of my VLANs, click Edit, change NOTHING, then click SAVE. Now I can login from  behind my VLANs that allow device management.
