01-07-2021 04:32 AM
Helo
I have a Inter-VLAN problem with a RV345.
VLAN1 192.168.1.1/24 DHCP cable on cable. And a Bizhub 223 printer/scanner.
VLAN2 192.168.2.1/24 DHCP almost everything on wifi (A VELOP AC6600 in bridge mode) Port 1 and 14 is tagged to this.
InterVLAN is on on both.
Can't ping anything inter-VLAN besides the Router. And if I try to connect to the shared folders from VLAN1 i reach 1 of 2 laptop on VLAN2 though the windows list both of them.
The problem is the network printer which try to send the scan with SMB v1/v2 can't reach none of them on VLAN2. All computer on VLAN1 and VLAN2 can print.
I tried to connect my laptop with cable. If it use the VLAN1 it works. But if I use port 14. and get IP from the VLAN2 it doesn't.
Any idea why it is not work?
Solved! Go to Solution.
01-07-2021 05:02 AM
just quetions - is the inter vlan ping and others working (except windows share ?)
if inter-vlan not working you need to fix that :
01-07-2021 05:02 AM
01-07-2021 06:23 AM
Nope. Ping doesnt work inter-VLAN. "Request timed out".
And VLAN-s are configured that way.
01-07-2021 07:12 AM
If you follow the steps in the link that balaji provided below you would have no issues. Double-check your end devices for firewall/windows defender or/and any antivirus software what might have a firewall and prevent Inter-VLAN communication.
Martin
