02-23-2011 08:47 AM
i bought a rvl200 last week and installed it last weekend. After using the router approx. 1 hour the router crashes and does not work anymore. I need to disconnect the router from power.
Does anyone knows if this is a configuration problem or a hardware problem?
Kind Regards,
Tobi
03-15-2011 07:33 AM
I am having the same problem. I configured a new RVL200 out of the box and put it online. Initally the router worked well for about six hours and then it crashed. I cycled power and functionality returned for about 15 minutes and then it crashed again.
Did you find a solution? Was it hardware or configuration?
Shaun
03-21-2011 01:29 PM
Hi Shaun,
i called the cisco hotline. They told me to reinstall the firmware with the effect that the router crashed while updating and had no functionality after this. Then the replaced the router. I got today a new one and it workes fine.
Hope that helps you
Kind Regards,
Tobi
