SA 540 Firmware Upgrade
gregh
I noticed that there was a new firmware upgrade available for the SA540 router.  From reading the release notes it appears that the new upgrade will reset the router to factory defaults and the recommended upgrade is to print off the pages that willl need to be manually reentered with previous information and then manually reenterthe information after the firmware upgrade.
This is quite a pain as the previous version upgrade required the same manual reentering of everything.  Is the upgrade path ever going to not require the manual reentering of information as this is getting a little old already or am I missing something in the upgrade procedures?
Thanks in advance.
alissitz
Level 4
Level 4
Hello and good evening,
I will forward your question to product managers.  More to come,
Andrew Lee Lissitz
I have spoken to the project manager about this, and this will be the last time that this happens.  I do apologize for the inconvenience.
