Smart Link Backup Not Switching to secondary wan when primary fails
SubbaMe
I have RV042 10/100 4-Port VPN Router and I have set up dual WAN to Smart Link Backup and WAN1 as primary.
WAN1 Configuration Details:
Upstream : 12500 Kbit/Sec
Downstream: 12500 Kbit/Sec
Enable Network Service Detection : Checked
Retry count : 5
Retry timeout : 30 seconds
When Fail : Keep System Log and Remove the Connection
Default Gateway : Checked
ISP Host : Unchecked
Remote Host : Checked and set to 8.8.8.8
DNS Lookup Host : Checked and set to google.com
WAN2 Configuration Details:
Retry count : 5
DNS Lookup Host : Checked and set to cisco.com
The issue is that it does not switch to WAN2 when WAN1 is offline and ping to 8.8.8.8 returns Request Timed Out.
My Device Details:
Firmware Version: v4.2.3.14
I have tried rebooting reconfiguring and still, it does not work as expected. Any kindly of help will be highly appreciated. Thank you.
balaji.bandi
this may not be great help but if you not come across check the config again.
https://www.cisco.com/c/en/us/support/docs/smb/routers/cisco-rv-series-small-business-routers/smb2985-configure-smart-link-backup-failover-on-rv042-rv042g-and-rv0.html
Other test, you can flip the WAN2 as primary and WAN1 as back and test if that works ?
suggest to post screenshot of configs
BB
Sujoy Paria
Please uncheck the ‘Default Gateway’ option, reduce the ‘Retry Count’ to 3 and ‘Retry Timeout’ to 3 seconds.
After that, please make sure both the Internet links are working fine individually and accordingly verify the Smart Link back up option. I hope it will work.
Once both the WAN links are up that time shut down one WAN connectivity, Internet should work fine via the other WAN link.
