01-15-2013 02:28 PM
As a raw test it is handy for us to ping externally tne WAN port of the SRP 527W, gives us a quick idea of whether it is responding.
Can someone advise how we configure the SRP 527W to allow this? FYI we have the inbulit SRP firewall enabled.
Cheers,
Dale.
Solved! Go to Solution.
01-15-2013 03:01 PM
Hi Dale, under network setup -> firewall -> firewall filter disable the "filter anonymous internet requests"
-Tom
Please mark answered for helpful posts
01-15-2013 03:01 PM
-Tom
01-15-2013 03:10 PM
Tom,
That did the trick - I looked at that setting however it seemed to sound a little wide ranging to just be "allow incoming ICMP requests"
Thank you for such a quick and correct response - solved!!
Cheers,
Dale.
