ā03-20-2012 05:57 AM
I have a pair of SRP-527W routers running latest firmware V 1.01.26. Everthing works fine. Except.... Have purchased a ZTE MF112 usb dongle as backup to the ADSL but router refuses to recognise it. In mobile network status shows as "Unable to Detect USB Mobile Modem".
Have tried a second dongle of the same type, cold reboot of router etc... but nothing. It is supposed to be supported in this release of firmware...?
Any suggestions or help much appreciated..
Many Thanks
ā03-20-2012 06:05 AM
ā03-20-2012 06:14 AM
The attachement refers to the previous version of firmware V 1.01.24.
The current version says it is supported...
But thanks anyway..
ā03-20-2012 06:51 AM
Hi Giles,
Sorry, this looks like a typo. We have just added supported for the MF112 in the 1.2.x release train for the SRP520-U and SRP540 products. It's not supported by the SRP520 series products running 1.1.x code though.
Andy
ā03-20-2012 07:11 AM
Hi Andy
Thanks for the response, the release notes specifically say support for the the MF112 was added in release 1.1.26 for the SRP-527.
http://www.cisco.com/en/US/docs/routers/srp520_series/srp521w/release_notes/srp520_rn_1.01.26.pdf
If that's not the case how do we know what devices are supported in this release..?
The problem is the majority of supported usb modems are older models as it seems the telecoms companies change them every other week, so getting hold of a supported one it tricky...
Giles
ā02-15-2013 01:08 AM
Hi Andrew!
Could you give us the correct modem matrix for non-U SRP 520 with firmware 1.01.27 ?
Regards, Yuriy
ā02-15-2013 01:09 AM
Hi, Giles!
I am also faced with the fact that 1.1.27 does not see MF112.
I solved the problem by flashing modem from MF112 into MF190 (because they are hardware identical).
Regards, Yuriy
