08-26-2012 03:21 AM
The status page doesn''t display the ADSL connect time, is there a simple way of seeing how log the ADSL has been connected ??
08-26-2012 08:27 AM
Hello Michael, under the Status -> Interface it does not display here? If you are familiar with SNMP that may be an option for you.
-Tom
Please rate helpful posts
08-26-2012 04:13 PM
Hi Tom
Thanks for your reply. The interface status just gives me packets transferred on each port.
The ADSL status is where I would have expected to find it but it just gives my sync speeds and various other things
Any chance CISCO might consider adding ADSL up ttime of this page
08-26-2012 03:28 PM
Try Adminsitration Menu > Remote Support option item > click on Collect Device Status Information.
You should get an automatic download of a log folder containing various compressed log files.
Look in the dump_dslmodem_cmd.txt file. The info you are looking for is there...I agree, not easy to find.
08-26-2012 04:15 PM
Thanks Gary
Thanks - thats what I thought. There is also a hidden disganostics page I read somewhere on this forum which would give me simlar info . But you have confirmed what I thought its not on a Status page .
Michael
