10-22-2014 02:45 AM
Hi all,
I use Cisco RV320 routers.
My VPN tunnel is established. I have multiple VLANs on each router, and I want only specified VLANs to use tunnel.
(I want VLAN 192.168.0.0 on router Lab to comunicate with 192.168.7.0 VLAN on router Pha)
Router name Lab - config
Local Group Setup | ||
Local Security Gateway Type: | IP only | |
IP Address: | XXX.XXX.XXX.XXX | |
Local Security Group Type: | Subnet | |
IP Address: | 192.168.0.0 | |
Subnet Mask: | 255.255.255.0 | |
Remote Group Setup | ||
Remote Security Gateway Type: | IP only | |
IP address | XXX.XXX.XXX.XXX | |
Remote Security Group Type: | Subnet | |
IP Address: | 192.168.7.0 | |
Subnet Mask | 255.255.255.0 |
Router name Pha - config
IP Address: | xxx.xxx.xxx.xxx | |
IP Address | xxx.xxx.xxx.xxx | |
With this configuration, I can ping from 192.168.0.0 to 192.168.7.0, but not from 192.168.7.0 to 19.168.0.0
When I change configuration and set everywhere 192.168.0.0, and subnet 255.255.0.0, it work's but
all VLAN networks, on both routers can use VPN tunnel and that is not what I need.
Do you have any suggestions to help me?
If you need any other information please ask me?
10-23-2014 12:21 PM
Once the tunnel is establish can you test to ping the LAN IP address of each router from remote side PC. Meaning from LAN 192.168.7.X PC try to ping 192.168.0.1 (assuming that this is the IP of the route). If this ping receive reply this would mean that the VPN tunnel is ok and the problem is purely routing issue.
Kremena
06-27-2015 03:27 PM
What if the tunnel shows established however the pings are not successful? what would you suggest would be a good way to troubleshoot?
06-29-2015 05:19 AM
You have to specify which ping is not successful:
-if ping to the remote gateway is not successful this could mean that the tunnel is not established at all, though it shows the opposite. It could be PFS mismatch. Or ESP filtered packets by the device infornt if any of the site is behind NAT
-if ping to a machine behind the router is not successful, this could be firewall on the PC itself or routing issue - usually when the gateway on the PC is not the router configured with the VPN
Kremena
06-30-2015 05:16 AM
Ping to remote gateway is not successful
https://supportforums.cisco.com/discussion/12543461/rv325-rv325-vpn-routing-issue
10-24-2014 10:56 AM
Jako,
Have you tried creating site to site tunnels for those different subnet/Vlans?
Reason all Vlans work is because you are using a class b subnet mask of 255.255.0.0 therefore you are using Network 192.168.x.x as suppose to a class c subnet mask of 255.255.255.0 which would be network of 192.168.0.x. So now all vlans are in tunnel communication would be seen in the 192.168.x.x.
Please mark or endorse this post if this helps you!
