binding e1 link
bikash_bd
Level 2
Level 2
Dear friend,
I have mwr1941 router. Would you provide me the configuration or steps so that the two E1 link will be metrged and acted under a single IP address. Please help me all out.
Bikash
5 Replies 5
paolo bevilacqua
Where do the two circuits connect to? Same router or different ones ?
same router
And what is on the other side? One or two routers? And, are these under your control ?
all is under my control
Just go through this link.Try the configuration, as mentioned in the link.
Revert back, if u need some more help.
http://www.cisco.com/en/US/tech/tk713/tk628/technologies_configuration_example09186a00800a5efa.shtml
