Routing and SD-WAN
Labels
Hello, everyoneI understand that EoMPLS can operate in two modes - port mode and VLAN mode. VLAN-tunneled interfaces are VC type 4 (0x0004), and port interfaces are VC type 5, or 0x0005.I have a simple xconnect built between two routers. This xconnec...
Mitrixsen by • Spotlight
  • 82 Views
  • 2 replies
Hello,I recently acquired a used Cisco ISR1111 for home use. Since the unit came without the original power supply, I had to build a custom power solution to power it up.During this process, I struggled to find documentation detailing the power conne...
Hello, I am picking a router for internet connectivity.  All I need is NATing, Static routing , VRF, IPSEC. I am planning to go for C8200-1N-4T. Bit confused whether I need DNA Advantage license or Essential is more than enough ? Please suggest
raghav.rai by • Level 3
  • 57064 Views
  • 10 replies
Yeah, so the title's a mouthful, but here's the gist:Android device managed by intuneAnyconnect using Azure for authenticationConditional access policy requiring device to be managed by Intune to joinDevice is 100% compliant with Intune, user can VPN...
Hello,This isn't particularly useful regarding anything operationally concerning EIGRP in general however I found myself incredibly curious... what does the "K" stand for in K-value? The only thing I could find that could perhaps be a possibility is ...
PinkiePie by • Community Member
  • 318 Views
  • 8 replies
