memory allocation issue
david de sousa
                   Hi guys,
I have a problem, a upgraded some switchs cisco, and then i have many alerts who say " Insufficient free memeory"
After taking a look, i see this logging message "
May 23 12:33:03: %SYS-2-MALLOCFAIL: Memory allocation of 32192 bytes failed from 0x803B6E5C, alignment 0
Pool: Processor  Free: 0  Cause: Not enough free memory
Alternate Pool: I/O  Free: 59808  Cause: Memory fragmentation
-Process= "SSH Process", ipl= 0, pid= 80
-Traceback= 801C4538 801CA1DC 801C5610 803B6E64 803B4408 803BB534 801B5E18 801B5E60 8014D664 8012F68C 8012FE9C 8015A950 8015AA3C 801517B0 8014F084 8015DBB4 "
anyone can help?
thanks
Gregory Snipes
Level 11
Level 11
What model of switch are these? What version of software were you upgrading from and to?
the model is C2950G-48-EI
i upgraded the ios image c2950-I6L2Q4-M to c2950-I6K2L2Q4
and then i have the alert of insufficient memory, but i did that on other switch, and all the 2940 and 2950 show the same issue. not all with this logging message, but all with insufficient memory alerts.
thanks
Matches http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCdw66805
I suggest moving to a non-crypto image or upgrade to a 2960 model.
