PPP Clocking Issues
somwicked
Community Member
PPP (full T1) WAN with 1750s at each end.
(router 1:clock=internal and router 2:clock=line) = no link (line down, protocol down)
(router 1:clock=line and router 2:clock=line) = link with lots of CRC and frame errors
I've done lots of digging and ran across enabling SCTE, inverting the transmit clock, setting the clock rate, etc .. and it makes my head hurt - very confusing.
How do I ensure the settings for clocking on the WICs and routers are set properly? How can I tell what they are set at now? And how do I change them if necessary?
I know router 1 should be clock internal and router 2 should be line but that is far as I understand this portion.
Guidance appreciated.
7 Replies 7
smif101
Level 9
Level 9
Are these routers directly connected to each other or do they go through a service provider for the T1 access? If directly connected then you would use a line/internal situation like described. However I believe that you are connected via the service provider and then you should have it setup as line/line. Is this a new circuit? Don't worry about inverting TC, that is done sometimes when the clock is out of phase with the data on a serial links and that doesn't apply because you have T1's. What you should do is work with the telco and start to loops on the circuit inhouse first and make sure you come up good, no errors and the line is up, after that, juat move the loop further to the distant end until you find the problem.
Thanks for the info.
I've been working with the telco who has swapped out some equipment, exercised the jacks(?), etc .. and I am currently monitoring.
The telco insists they are not providing any clocking on the line.
As far as I know, its a clear channel T1 and even they agree one of my routers should be providing clocking.
When i switch over to clock source internal, the line disappears & never comes back up. I've also noticed that adding the clock rate shows nothing in the running config - which I think is kinda odd.
Can you post your configs?
Not a problem.
These do not show the clock set to internal - yet this is the only way to get a link between the sites.
The telco has recently mentioned something about a transmit frequency - which i am totally lost about. Not quite sure what they are looking for.
main#show startup-config
Using 954 out of 29688 bytes
version 12.2
hostname mcv-zeeland
enable secret xxxx
enable password xxxx
memory-size iomem 25
ip subnet-zero
no ip domain-lookup
ip audit notify log
ip audit po max-events 100
call rsvp-sync
class-map match-all VOIP
match access-group name VoiceOverIP
policy-map SET_PRECEDENCE
class VOIP
set ip precedence 5
interface FastEthernet0
ip address 192.168.0.5 255.255.255.0
service-policy input SET_PRECEDENCE
speed auto
interface Serial0
description WAN to remote
ip address 192.168.33.1 255.255.255.0
encapsulation ppp
router rip
version 2
network 192.168.0.0
network 192.168.33.0
no auto-summary
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.0.1
no ip http server
line con 0
password mcv
login
line aux 0
line vty 0 4
password mcv
login
end
remote#show startup-config
Using 1239 out of 29688 bytes
version 12.2
hostname mcv-bearlake
enable secret xxxx
ip subnet-zero
no ip domain-lookup
no ip dhcp conflict logging
ip dhcp excluded-address 192.168.2.1 192.168.2.99
ip dhcp pool DPL
network 192.168.2.0 255.255.255.0
default-router 192.168.2.5
domain-name domain.com
dns-server 192.168.0.2
netbios-name-server 192.168.0.2
netbios-node-type h-node
ip audit notify log
call rsvp-sync
class VOIP
set ip precedence 5
ip address 192.168.2.5 255.255.255.0
speed auto
interface Serial0
description WAN to main
ip address 192.168.33.2 255.255.255.0
encapsulation ppp
router rip
version 2
network 192.168.2.0
no auto-summary
ip classless
no ip http server
line con 0
password xxx
login
line aux 0
line vty 0 4
password mcv
login
end
can you post the output of show controllers s0.
The clockrate command will work if you have dce cables not dte.
Off on a tangent .. we've been fighting this for a week or so. Out of curiosity, I replaced the 1750 with a 1720 and everything worked as expected.
Apparently, there are issues with the 1750 that we originally tried using.
Thanks for your assist to this point - looks like it was a hardware issue.
