0d.0b0d.0b0d.0b0d.0b0d.0b0d - Telnet
neidlein.p
Hi community,
we have a funny thing on a ISR4331
xxx#ping ipv6 www.cisco.com
% Unrecognized host or address, or protocol not running.
xxx#telnet www.cisco.com 80
Trying 0d.0b0d.0b0d.0b0d.0b0d.0b0d, 80 ...
% Connection aborted
xxx#ping www.cisco.com
Sending 5, 100-byte ICMP Echos to 104.97.66.117, timeout is 2 seconds:
Success rate is 40 percent (2/5), round-trip min/avg/max = 86/162/239 ms
xxx#
xxx# show version | incl 4b
Cisco IOS XE Software, Version 03.16.04b.S - Extended Support Release
Cisco IOS Software, ISR Software (X86_64_LINUX_IOSD-UNIVERSALK9-M), Version 15.5(3)S4b, RELEASE SOFTWARE (fc1)
System image file is "bootflash:isr4300-universalk9.03.16.04b.S.155-3.S4b-ext.SPA.bin"
xxx#
When we try to telnet to a endhost it's trying a strange address.
Is this a bug ? do you observe something similar on usr ISR4k ?
estebanzarikian
Hi! I have the same problem, were you able to fix it?
I tried globally disabling IPv6 with the no ipv6 unicast-routing command, also changed name servers, tried with different hostnames. Asides from telnet it also seems to affect the http client from IP SLA which I use regularly also. Any ideas?
Best regards,
Esteban
I was having the same issue with telnet.  I added /ipv4 to the end of the end of the command and it worked fine.
router>tel cisco.com
Trying 0d.0b0d.0b0d.0b0d.0b0d.0b0d ...
router>tel cisco.com /ipv4
Trying cisco.com (72.163.4.185)...
