1605-R Duplex Issue
DanielO
IOS 12.1
I cant set the duplex to full on my eth0 and this is preventing my connection from runnign stable. Supposedly I am supposed to be able to config-interface and run the command duplex full, but it does not recognize the command duplex. Any ideas? Should I update my IOS?
scottmac
Level 10
Level 10
10BASE-T is half-duplex. There is no (or wasn't at the design-time) spec for 10Meg Full-Duplex.
It won't matter what IOS you run, chances are the hardware doesn't support full duplex 10Meg.
Good Luck
Scott
