Loses ip classless & ip subnet-zero
during the resolution of an breakdown I have noticed that the commands "ip classless" and "ip subnet-zero" are not more visualize to you in the configuration, not even with show running-config full.
The IOS version is Entbase12.4(5).
Someone knows if there are indications in merit?
Thanks!
Dave
farkascsgy
Level 4
Level 4
If you apply a command like ip subnet-zero or some other and it is not shown in the config, it means that in default the command has been applied...
bye
FCS
Please rate me if I helped.
Dave
I have some routers running 12.4(3) a different feature set than yours. I checked my routers and both ip classless and ip subnet-zero do still appear in the running config. So I do not think that there is a general change release wide. Perhaps it is something in your specific version and feature set.
FCS makes reference to the fact that most commands do not show up in the running-config if they are set to their default value. Both ip classless and ip subnet-zero have been exceptions to this, because in their history the default has changed (both were originally not enabled by default and now both are enabled by default). It is possible that in your version of code that someone decided to hide them to conform to the usual do not show commands when set to default values.
I doubt that the default behavior has changed.
Rick
Rick
The behavior has changed in 12.4(5). Since "ip classless" and "ip subnet-zero" are both the default, they are not seen in the config anymore.
Hope this helps,
