1720 Router problem - (bad checksum: 0x2dca)
electoralreform
I recently picked up a 1700 router but am unable to reload the IOS. I'm trying to recover it through ROMMON but it keeps failing:
rommon 3 > dir flash:
File size Checksum File name
3682960 bytes (0x383290) 0x6dca c1700-osy56i-mz_120-3_T3.bin (bad checksum: 0x2dca)
25 bytes (0x19) 0xaca0 snmpengineid
Can anyone enlighten me to the 'bad checksum'?
Thanks in advance
Damian Coverly
yilmaza
IOS image size may missing or damage, upgrade IOS file from rommon via xmodem or tftp.
amit-singh
Level 8
Level 8
Hi Damian,
The IOS is corrupted on the router that is why it is unable to boot properly.
Please use the TFTPD rommon recovery procedure to get the router back up again.
Please us ethe link below for the recovery:
http://www.cisco.com/univercd/cc/td/doc/product/access/acs_mod/1700/1700swcg/rom_mon.htm#wp1005241
HTH,
-amit singh
smothuku
Level 7
Level 7
Hi Damian ,
IOS which you rae trying to load in 1700 router is corrupted .Try to download ios from cisco and follow the steps mentioned in the below link.
http://www.cisco.com/warp/public/130/sw_upgrade_proc_ram.shtml
Hope it helps you.
satish
Hi all,
Thanks for your responses. I was originally going through the recovery steps as you've mentioned, but kept getting:
_____
*** Machine Check Exception ***
PC = 0x80fa0c0c, Vector = 0x200, SP = 0x8000636c
monitor: command "tftpdnld" aborted due to exception
____
....turns out the image was a couple of MB to big. Downloaded a smaller one and it's all sorted.
Thanks again
-Damian.
