1841 and object tracking
jjoseph01
Level 3
Level 3
Anyone know of object tracking for two ISP links is supported on an 1841?
6 Replies 6
jjoseph01
Level 3
Level 3
I think it does, reading through other posts.
John
I have not done object tracking on an 1841 so can not speak from experience about this. But I am confident that object tracking is supported on the 1841.
Rick
Rick
foxbatreco
Level 3
Level 3
Yes , OB tracking is supported on 1841..
To add up to the replies posted by fellow netpro's Cisco 1841 supports Object Tracking subjected to that you have required feature set installed in it.
We do normally use Advanced SP Services to have the same .So do make sure that you have this feature of the ios code to have OB tracking feature enabled on your router..
regds
Hii..
if am correct it should have the advipservice-K9 IOS for Object tracking configs.
Yes, it is supported in Advanced Ip services. You need atleast 256MB DRAM for the same. You have to upgrade the memory and flash on the router for the same.
-amit singh
