PPPOA Client
msubtain
Is there any way i can use ASA 5510 (software version 7.2(2)) as PPPOA client?
I can see the only PPPOE option in ASDM.
thanks
paolo bevilacqua
the PIX does not have ATM interface so you cannot use PPPoA. True PPPoA is not much used, but if you need that, you need to use a router.
