1841 authentication issues when creating L2TP/IPSec VPN for client access.
accarda
Hello everyone,
hopefully you might give me some idea on what to look for in order to solve this issue.
I'm trying to setup L2TP/IPSec access on my 1841 in order to allow my Mac client to access it when outside.
This is a second step of an already working config that I have about accessing my 1841 via IPSec, which works fine.
But I'd like to setup L2TP/IPSec, because on recent MacOSX they have left an option to "forward all traffic through VPN" only when you use L2TP, otherwise when using native Cisco IPSec client mode MacOSX won't have such option.
So I checked on this forum and found a possible configuration to try, but I'm having issues I believe with L2TP authentication.
I was following this discussion https://community.cisco.com/t5/security-documents/l2tp-over-ipsec-on-cisco-ios-router-using-windows-8/ta-p/3142831/show-comments/true
Consider that I have already tested my MacOSX as client with another router, where I have successfully enabled L2TP/IPSec with no issues in the same environment of access router behind NAT.
So I have forwarded all 3 UDP ports 500, 1701 and 4500 to reach my 1841.
In the Cisco config for only IPSec I use only 500 and 4500 indeed and it works fine.
What I can see right now is that IPSec portion works as I can see trace of my client being accessing and establishing the connection, but then the VPN client terminates saying authentication failed.
Here below is the relevant part of the current config that I'm testing on my 1841; I have checked IPSec secret and L2TP username/password to make sure no typo during login, but no success to authenticate.
aaa new-model
aaa authentication ppp VPDN_AUTH local
aaa session-id common
ip cef
no ip domain lookup
ip domain name ddns.net
ip name-server 208.67.222.222
ip name-server 208.67.220.220
vpdn enable
vpdn-group L2TP
! Default L2TP VPDN group
 accept-dialin
  protocol l2tp
  virtual-template 1
 no l2tp tunnel authentication
username USER privilege 15 secret 5 XXXXXXXXXX
crypto isakmp policy 10
 encr 3des
 authentication pre-share
 group 2
 lifetime 3600
crypto isakmp key SECRET address 0.0.0.0 0.0.0.0
crypto ipsec transform-set L2TP-Set2 esp-3des esp-sha-hmac
 mode transport
crypto dynamic-map EXT_DYNAMIC_MAP 10
 set nat demux
 set transform-set L2TP-Set2
crypto map EXT_MAP 10 ipsec-isakmp dynamic EXT_DYNAMIC_MAP
interface Loopback1
 description Loopback-IPSec-pool
 ip address 10.10.20.1 255.255.255.255
interface FastEthernet0/1
 ip address 192.168.1.2 255.255.255.248
 ip access-group WAN in
 ip verify unicast reverse-path
 ip flow ingress
 ip flow egress
 ip nat outside
 ip virtual-reassembly
 no ip mroute-cache
 duplex auto
 speed 100
 crypto map EXT_MAP
interface Virtual-Template1
 ip unnumbered Loopback1
 peer default ip address pool VPN_CLIENT_POOL
 ppp authentication ms-chap-v2 VPDN_AUTH
ip local pool VPN_CLIENT_POOL 10.10.20.2 10.10.20.100
ip nat inside source static udp 192.168.1.2 500 192.168.1.2 500 extendable
ip nat inside source static udp 192.168.1.2 1701 192.168.1.2 1701 extendable
ip nat inside source static udp 192.168.1.2 4500 192.168.1.2 4500 extendable
ip access-list extended WAN
 permit udp any host 192.168.1.2 eq isakmp
 permit udp any host 192.168.1.2 eq 1701
 permit udp any host 192.168.1.2 eq non500-isakmp
Thanks in advance for any suggestion that you can provide.
Armando.
Deepak Kumar
Sorry, I missed the description. So I deleted.
Deepak Kumar
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
Hi Deepak,
those ports are correctly forwarded to the Cisco.
Here is the sh ip access-list WAN output:
Extended IP access list WAN
10 permit udp any host 192.168.1.2 eq isakmp (31 matches)
20 permit udp any host 192.168.1.2 eq 1701 (108 matches)
30 permit udp any host 192.168.1.2 eq non500-isakmp (252 matches)
These are my tests in trying to access the VPN and you can see several matches on all those ports from outside Internet.
As I said this config works fine when I set the same for accessing the VPN only with IPSec (where definition for UDP 1701 is not there of course).
Armando.
accarda
Actually to add to this I have checked with debug vpdn for some error and I have got this portion of report, where it says some vendor issues. May be MacOSX L2TP/IPSec is not compatible with Cisco IOS ?????
7:37:48.841 CET: L2TP tnl   0100F:000070FD:   VPDN Session count now 1
019278: Feb 22 17:37:48.841 CET: L2TP _____:0100F:00000011: VPDN: process AVPs
019279: Feb 22 17:37:48.841 CET: L2TP _____:0100F:00000011: Local AC is now UP
019280: Feb 22 17:37:48.841 CET: L2TP _____:0100F:00000011: Remote AC is now UP
019281: Feb 22 17:37:48.841 CET: L2TP _____:0100F:00000011:
019282: Feb 22 17:37:48.861 CET: L2TP _____:0100F:00000011:   App type set to VPDN
019283: Feb 22 17:37:48.861 CET: L2TP 00010:0100F:00000011:   Session classname VPDN group L2TP ip addr 0.0.0.0
019284: Feb 22 17:37:48.861 CET: L2TP 00010:0100F:00000011:   UDP checksum ignore is enabled
019285: Feb 22 17:37:48.861 CET: L2TP 00010:0100F:00000011:   Framing set to sync
019286: Feb 22 17:37:48.861 CET: L2TP 00010:0100F:00000011:   Bearer set to none
019287: Feb 22 17:37:48.861 CET: L2TP 00010:0100F:00000011:   group set to "VPDN group L2TP ip addr 0.0.0.0"
019288: Feb 22 17:37:48.861 CET: L2TP 00010:0100F:00000011: FSM-Sn ev ICRQ-OK
019289: Feb 22 17:37:48.865 CET: L2TP 00010:0100F:00000011: FSM-Sn    Proc-ICRQ->Wt-Tx-ICRP
019290: Feb 22 17:37:48.865 CET: L2TP 00010:0100F:00000011: FSM-Sn do Tx-ICRP-Local-Check
019291: Feb 22 17:37:48.865 CET: L2TP 00010:0100F:00000011: FSM-Sn ev Local-Cont
019292: Feb 22 17:37:48.865 CET: L2TP 00010:0100F:00000011: FSM-Sn    Wt-Tx-ICRP->Wt-Rx-ICCN
019293: Feb 22 17:37:48.865 CET: L2TP 00010:0100F:00000011: FSM-Sn do Tx-ICRP
019294: Feb 22 17:37:48.865 CET: L2TP 00010:0100F:00000011: Open sock 192.168.1.2:1701->W.X.Y.Z:53113
019295: Feb 22 17:37:48.865 CET: L2TP 00010:0100F:00000011: FSM-Sn ev Sock-Ready
019296: Feb 22 17:37:48.865 CET: L2TP 00010:0100F:00000011: FSM-Sn    in Wt-Rx-ICCN
019297: Feb 22 17:37:48.865 CET: L2TP 00010:0100F:00000011: FSM-Sn do Ignore-Sock-Up
019298: Feb 22 17:37:48.869 CET: L2TP 00010:0100F:00000011:
019299: Feb 22 17:37:48.873 CET: L2TP 00010:0100F:00000011: FSM-Sn ev DP-Setup
          0: Feb 22 17:37:48.873 CET: L2TP 00010:0100F:00000011: FSM-Sn    in Wt-Rx-ICCN
019301: Feb 22 17:37:48.873 CET: L2TP 00010:0100F:00000011: FSM-Sn do Ignore-DP-Setup
019302: Feb 22 17:37:49.005 CET: L2TP tnl   0100F:000070FD: Control connection authentication skipped/passed.
019303: Feb 22 17:37:49.005 CET: L2TP 00010:0100F:00000011: FSM-Sn ev Rx-ICCN
019304: Feb 22 17:37:49.005 CET: L2TP 00010:0100F:00000011: FSM-Sn    Wt-Rx-ICCN->Proc-ICCN
019305: Feb 22 17:37:49.005 CET: L2TP 00010:0100F:00000011: FSM-Sn do Rx-ICCN
019306: Feb 22 17:37:49.005 CET: L2TP 00010:0100F:00000011:   MTU is 65535
019307: Feb 22 17:37:49.009 CET: L2TP 00010:0100F:00000011: Session data plane UP
019308: Feb 22 17:37:49.009 CET: L2TP 00010:0100F:00000011: VPDN: process AVPs
019309: Feb 22 17:37:49.009 CET: L2TP 00010:0100F:00000011:
019310: Feb 22 17:37:49.009 CET: L2TP 00010:0100F:00000011: FSM-Sn ev ICCN-OK
019311: Feb 22 17:37:49.009 CET: L2TP 00010:0100F:00000011: FSM-Sn    Proc-ICCN->established
019312: Feb 22 17:37:49.009 CET: L2TP 00010:0100F:00000011: FSM-Sn do Established
019313: Feb 22 17:37:49.009 CET: L2TP 00010:0100F:00000011: Session up
019314: Feb 22 17:37:49.009 CET: L2TP 00010:0100F:00000011:   192.168.1.2<->W.X.Y.255
019315: Feb 22 17:37:52.125 CET: L2TP tnl   0100F:000070FD: Control connection authentication skipped/passed.
019316: Feb 22 17:37:52.125 CET: L2TP 00010:0100F:00000011: FSM-Sn ev Rx-CDN
019317: Feb 22 17:37:52.125 CET: L2TP 00010:0100F:00000011: FSM-Sn    established->Idle
019318: Feb 22 17:37:52.129 CET: L2TP 00010:0100F:00000011: FSM-Sn do Rx-CDN
019319: Feb 22 17:37:52.129 CET: L2TP 00010:0100F:00000011: VPDN: process AVPs
019320: Feb 22 17:37:52.129 CET: L2TP 00010:0100F:00000011:
019321: Feb 22 17:37:52.129 CET: L2TP 00010:0100F:00000011: Shutting down session
019322: Feb 22 17:37:52.129 CET: L2TP 00010:0100F:00000011:   Result Code
019323: Feb 22 17:37:52.129 CET: L2TP 00010:0100F:00000011:     Reserved (0)
019324: Feb 22 17:37:52.129 CET: L2TP 00010:0100F:00000011:   Error Code
019325: Feb 22 17:37:52.129 CET: L2TP 00010:0100F:00000011:     No error (0)
019326: Feb 22 17:37:52.129 CET: L2TP 00010:0100F:00000011:   Vendor Error
019327: Feb 22 17:37:52.129 CET: L2TP 00010:0100F:00000011:     None (0)
019328: Feb 22 17:37:52.129 CET: L2TP 00010:0100F:00000011:
019329: Feb 22 17:37:52.129 CET: L2TP 00010:0100F:00000011: FSM-Sn ev Shut
019330: Feb 22 17:37:52.129 CET: L2TP 00010:0100F:00000011: FSM-Sn    Idle->Dead
019331: Feb 22 17:37:52.129 CET: L2TP 00010:0100F:00000011: FSM-Sn do Destroy
019332: Feb 22 17:37:52.129 CET: L2TP 00010:0100F:00000011:
019333: Feb 22 17:37:52.129 CET: L2TP 00010:0100F:00000011: Session down
019334: Feb 22 17:37:52.129 CET: L2TP 00010:0100F:00000011:   192.168.1.2<->W.X.Y.255
019335: Feb 22 17:37:52.129 CET: L2TP 00010:0100F:00000011: Destroying session
019336: Feb 22 17:37:52.133 CET: L2TP 00010:0100F:00000011: Request teardown data plane
019337: Feb 22 17:37:52.133 CET: L2TP tnl   0100F:000070FD: FSM-CC ev Session-Disc
019338: Feb 22 17:37:52.133 CET: L2TP tnl   0100F:000070FD: FSM-CC    in established
019339: Feb 22 17:37:52.133 CET: L2TP tnl   0100F:000070FD: FSM-CC do Session-Disc-Est
019340: Feb 22 17:37:52.133 CET: L2TP tnl   0100F:00007
