1841 Router - adding a Fast/Ethernet WIC
tparrettcisco
Have an 1841 Router that's currently passing traffic to from my 192.168.1.x network to another site with my 192.168.9.x network.  I want to put a new network at this same location, a 192.168.10.x network, but the 1841 router only has 2 Fast/Ethernet ports.  Can I add a 1 port HWIC to this router to handle the routing for the .10.x network?  Am I even thinking this through correctly?  Struggling to wrap my head around this.  Any help is appreciated.
Kai Onken
try this Cisco Document. This will help you to find your information:
http://www.cisco.com/en/US/prod/collateral/routers/ps5854/product_data_sheet0900aecd80581fe6.html
--- cut start ---
   1- and 2-Port Fast Ethernet High-Speed WIC for Cisco Integrated Services Routers
Router Chassis                                  Cisco 1841
Maximum Number of 1 Port HWICs     1
Maximum Number of 2 Port HWICs     1
Min. IOS                                           12.4(20)T - IP Base
--- cut end ---
Kind regards
Kai
Kai Onken
--- cut start ---
--- cut end ---
Kind regards
Kai
