12-04-2006 01:13 PM - edited 03-03-2019 02:54 PM
Good Day all,
I have an 1841 router that was working perfectly untill a reboot. After rebooting the router constantly boots into ROMMON. I changed the flash card for the router and it works ok. But using the original flash it boots to ROMMON. Below is the bootup message that appears:
System Bootstrap, Version 12.3(8r)T9, RELEASE SOFTWARE (fc1)
Copyright (c) 2004 by cisco Systems, Inc.
PLD version 0x10
GIO ASIC version 0x127
c1841 processor with 131072 Kbytes of main memory
Main memory is configured to 64 bit mode with parity disabled
Readonly ROMMON initialized
program load complete, entry point: 0x8000f000, size: 0xc100
Initializing ATA monitor library.......
boot: cannot determine first executable file name on device "flash:"
PLD version 0x10
GIO ASIC version 0x127c1841 processor with 131072 Kbytes of main memory
Readonly ROMMON initializedprogram load complete, entry point: 0x8000f000, size: 0xc100
PLD version 0x1
rommon 1 >
I would like to know what causes this problem and how to fix it....if possible. I have had this router for only a month.
Thank You.
12-04-2006 08:20 PM
HI;
POssibly the Flash is couurpted. do contact cisco TAC and get it replaced or get TAC support for formatting and installing IOS on compact flash
since it a month old device only....
Nil
12-04-2006 08:38 PM
Hi Friend,
The router is not able to find a valid IOS in the flash and hence it is booting to ROMMON
This may be caused due to a corrupted flash file or the IOS is deleted accidently
check out the link for disaster recovery from rommonitor
http://www.cisco.com/en/US/products/ps5854/prod_configuration_guide09186a00802c35e9.html
HTH, rate if it does
Narayan
