1841 router <--> home router
frank.ring
here is a simple setup. The home router is also modem/gateway and has its own DHCP server.
How do I get the home router to recognize the network 10.0.0.0/24, it does not have the possibility to enter static routes.
Ping is possible in the 10-network, I can ping the outer interface on the router but nothing comes back from the home router. Which setup would work?
Joseph W. Doherty
Many home routers will only directly support a single, or possible two (2nd for wireless), 192.168.x.x/24 networks; possibly that's your case too.  (One reason for supporting only one or two /24s, as a /24 supports 254 host IPs, it's often assumed this is sufficient to support a home [or small business].)
Your 1841 may be capable of NAT/PAT.  If so, you can have your 10.0.0.0/24 network behind a 192.168.x.x. IP supported by your home router.
Joseph W. Doherty
Thanks a lo Joseph, the solution with NAT/PAT was successful. Now there are more challenges with port forwarding waiting for me - there is still a lot to learn on the cli
You might find, port forwarding, a particular challenge when using PAT.
Much to learn on a 1841 CLI?  Indeed.  I recall the 1841 is, more or less, about a full features (depending on installed IOS) as larger ISRs.
Basically the CLI is intuitive, here is the configuration as I currently have it working (for testing purposes only - here on a 1812 router)
Network 192.168.10.0/24 is set up as vlan 10.
The 192.168.1.0/24 network is the side of the "provider".
Interesting maybe for other forum members are the lines to "ip nat inside / outside".
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.10.1 192.168.10.100
ip dhcp excluded-address 192.168.10.150 192.168.10.254
ip dhcp pool vPool10
network 192.168.10.0 255.255.255.0
default-router 192.168.10.1
dns-server 8.8.8.8
archive
log config
hidekeys
interface FastEthernet0
no ip address
shutdown
duplex auto
speed auto
interface FastEthernet1
ip address dhcp
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
interface BRI0
no ip address
encapsulation hdlc
shutdown
isdn point-to-point-setup
interface FastEthernet2
switchport access vlan 10
interface FastEthernet3
interface FastEthernet4
shutdown
interface FastEthernet5
shutdown
interface FastEthernet6
shutdown
interface FastEthernet7
shutdown
interface FastEthernet8
shutdown
interface FastEthernet9
shutdown
interface Vlan1
no ip address
shutdown
interface Vlan10
ip address 192.168.10.1 255.255.255.0
ip nat inside
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list 10 interface FastEthernet1 overload
access-list 10 permit 192.168.10.0 0.0.0.255
dialer-list 1 protocol ip permit
