Need help with setting up OSPF on this packet tracer
VM24
I attached the packet tracer file, wondering what I'm doing wrong because I've tried so many things and it just doesn't work, can't get any pings working and if I do the ospf neighbor command it shows nothing. If someone can check the configs and tell me what I'm messing up on that would be great.
Martin L
So far, I removed passive interface and hello-interval 30, then added ip ospf 10 area 0 on all interfaces.
Branch-1  has wrong IP address/mask towards LAN; not on the same network.
209.165.201.0 and 209.165.200.0  are not advertised;  static route on Internet router and HQ ?
Regards, ML
**Please Rate All Helpful Responses **
NetworkDave
@VM24,
Welcome to the community!
Please provide the passwords for the routers, Branch-2 and Internet.
To establish neighbor adjacency between the HQs and Branch-1 routers:
HQ(config)#router ospf 10
HQ(config-router)#no passive-interface g0/0
HQ(config-router)#end
HQ#
Also, as @Martin L mentioned, please check the IP addressing scheme and associated configurations.
