1841 routing table size
andre.ortega
How many routes the 1841 supports in routing table?
How many you need? With an ip only image it can keep the full internet table with few BGP peers.
evsrajatgupta
Hi andre.ortega,
The Capacity of a router to fold route depands on the Dram of the router. Moveover the perfomance of the router os depandence both on the processer and the dram.
Please rate if it help
guruprasadr
Level 7
Level 7
HI Andre, [Pls Rate if HELPS]
Refer Link below for Portable Product Sheets: with which the performance and any other can be measured.
http://www.cisco.com/web/partners/tools/quickreference/index.html
Hope I am Informative.
Pls Rate if HELPS
Best Regards,
Guru Prasad R
but I need of the number routes in routing table.
Regards.
