1841 WIC-1b-S/T vs Alcatel4400
nthepault
I'm trying to configure my BRI interface in "network protocol-emulate network" and "layer1-emulate network" but i don't have this second command.
Is someone have allready to that with this type of interface ?
I've to configure this because the ISDN line of my telco is in user mode only.
CISCO 1841
IOS C1841-IPBASE-M
12.4(15)T12
WIC-1B-S/T-V3
5 Replies 5
Could you please apply below command,
Router(config-if)# isdn protocol-emulate {user | network} ! Since you are using for user , enter user.
Please rate the post if it helps.
Jyoti
I can enter this command :
Router(config-if)# isdn protocol-emulate NETWORK
But it's only for the layers 2&3. My problem is with the layer 1.
I've tried to make a crossover cable but it doesn't work.
I've see in me research on the web that there was the command :
Router(config-if)# layer1-emulate network
but i think that it's only for VIC inerfaces and i've a WIC.
paolo bevilacqua
What are you trying to do? That card does NOT support voice.
It's to make a little WAN between to site and noly for DATA, not for voice.
And what would the architecure of the "little WAN" ?
Seems to be there is no practical use.
