Showing results forĀ
Search instead forĀ
Did you mean:Ā
1941 Auto failover and load balance
rsjavahar
HI ...
I have configured 1941-sec router for my client 3 months back  for Autofailover and Load balance. it worked well. but from past 20days .. auto failover is working .. one the 1st ISP cable physically disconnects.. and not able to access the device from remotely thorugh 1st ISP... here i am adding the configuration ...
XXX.YYY.ZZZ,,, is primary ISP
XXX.XXX.XXX....secondary ISP
thanks in advance
RSJ
#sh run
boot-start-marker
boot-end-marker
enable password <removed>
no aaa new-model
ip cef
ip dhcp excluded-address 192.168.1.151
ip dhcp pool satwic
network 192.168.1.0 255.255.255.0
default-router 192.168.1.1
dns-server 8.8.8.8 4.4.4.4 XXX.YYY.190.180 XXX.XXX.244.3
ip name-server 8.8.8.8
ip name-server 4.4.4.4
no ipv6 cef
crypto pki trustpoint TP-self-signed-3334084634
license udi pid CISCO1941/K9 sn ABCDEF123456
username <REMOVED> privilege 15 password 0 <REMOVED>
redundancy
track 1 ip sla 1 reachability
delay down 9 up 10
track 2 ip sla 2 reachability
delay down 9 up 10
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
ip address XXX.YYY.ZZZ.74 255.255.255.252
ip nat outside
ip virtual-reassembly in
duplex auto
speed auto
interface GigabitEthernet0/1
ip flow ingress
ip nat inside
duplex auto
speed auto
interface FastEthernet0/1/0
ip address XXX.XXX.XXX.114 255.255.255.224
  ip nat outside
duplex auto
speed auto
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip flow-top-talkers
top 20
sort-by bytes
ip nat inside source route-map isp1 interface GigabitEthernet0/0 overload
ip nat inside source route-map isp2 interface FastEthernet0/1/0 overload
ip nat inside source static 192.168.1.100 XXX.YYY.ZZZ.96
ip route 0.0.0.0 0.0.0.0 XXX.YYY.ZZZ.73 track 1
ip route 0.0.0.0 0.0.0.0 XXX.XXX.XXX.97 track 2
ip sla auto discovery
ip sla 1
icmp-echo XXX.YYY.ZZZ.73 source-interface GigabitEthernet0/0
frequency 5000
threshold 2
ip sla schedule 1 life forever start-time now
ip sla 2
icmp-echo XXX.XXX.XXX.97 source-interface FastEthernet0/1/0
frequency 5000
threshold 2
ip sla schedule 2 life forever start-time now
access-list 100 permit ip 192.168.1.0 0.0.0.255 any
route-map isp2 permit 10
match ip address 100
match interface FastEthernet0/1/0
route-map isp1 permit 10
match interface GigabitEthernet0/0
snmp-server ifindex persist
snmp-server enable traps entity-sensor threshold
control-plane
line con 0
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
password <REMOVED>
login
transport input all
scheduler allocate 20000 1000
end
5 Replies 5
cadet alain
So when primary path is down what happens that you find unusual? You can't do what from outside ?
Alain
Hi Alain
if primary goes down.. secondary is not comming up automatically, ifi remove the primary cable then only the secondary line will come......
if both links are up i am not able to access the device through the primary link...
thanks in advance
RSJ
first do this:
no ip route 0.0.0.0 0.0.0.0 XXX.YYY.ZZZ.73
no ip route 0.0.0.0 0.0.0.0 XXX.XXX.XXX.97
then take primary down and tell us if secondary comes up now and if not post sh track 1 and sh track 2  output
Alain
HI
Please find the out put
1). after no default route
XXXX_RTR#sh track
Track 1
  IP SLA 1 reachability
  Reachability is Up
    14 changes, last change 05:27:47
  Delay up 10 secs, down 9 secs
  Latest operation return code: OK
  Latest RTT (millisecs) 1
  Tracked by:
    STATIC-IP-ROUTING 0
Track 2
  IP SLA 2 reachability
  Reachability is Up
    4 changes, last change 3w2d
  Tracked by:
    STATIC-IP-ROUTING 0
2). with default route
XXXXXX_RTR#sh track
Track 1
  Reachability is Up
    10 changes, last change 05:27:47
  Tracked by:
    STATIC-IP-ROUTING 0
Track 2
  Reachability is Up
  Tracked by:
    STATIC-IP-ROUTING 0
Thanks in advance
That's not exactly what I asked.
Did you clear the 2 static routes without the track command ?
Then when bringing down primary, did you see the track object 1 go down ?
If not then can you do this and tell us if it solves your problem:
no ip sla 1
ip sla 1
icmp-echob8.8.8.8 source-interface GigabitEthernet0/0
frequency 5000
threshold 2
no ip sla 2
ip sla 2
icmp-echo 8.8.4.4 source-interface FastEthernet0/1/0
frequency 5000
threshold 2
access-list 101 permit icmp any host 8.8.8.8 echo
access-list 102 permit icmp any host 8.8.4.4 echo
route-map SLA p 10
match ip add 101
set ip next-hop XXX.YYY.ZZZ.73
route-map SLA p 20
match ip add 102
set ip next-hop XXX.XXX.XXX.97
ip local policy route-map SLA
Alain
