2 Different VLans using same 10.78.x.x Network Scheme
chueymtz
I would like to know if it is possible to create 2 vlans ex: VLan 300 Wifi and VLan 400 Voip, am I able to set dhcp pool and ip scheme of ex 10.78.2.x /24. Can i use half of the ip's for VLan 300 and the other half for Vlan400? Any suggestions?
20 Replies 20
It's weird because the first part of it 10.78.2.1 vlan is able get online I haven't made any changes that would allow it to but it's working the way we want it.
Check
Ip nat inside <- under the both vlan svi
Check the acl you use in NAT overload
MHM
@chueymtz  mr @matthew2587  is correct.
MHM
Curious on your subnet calculator because mine shows this:
The most relevant question is what you'd like to achieve. I assume you are on the way to doing something terrible...
I agree, but it's the only choice I have. I have a group of ip's that go into a third party firewall and they won't give me another group of ip's so I have to use this network.
