Showing results forĀ
Search instead forĀ
Did you mean:Ā
225ms delays
Hi All
I got a vpn conection bweeten US and Australia, my delay time are 225ms and Im running 3 servers with Microsoft Dynamics AX 200.How can I decerese such hi delays.?
Is WAAS will be a good option here or I need to speak with the service  provider to see my options...
thanks guys
Carlos
Joseph W. Doherty
Disclaimer
The   Author of this posting offers the information contained within this   posting without consideration and with the reader's understanding that   there's no implied or expressed suitability or fitness for any purpose.   Information provided is for informational purposes only and should not   be construed as rendering professional advice of any kind. Usage of  this  posting's information is solely at reader's own risk.
Liability Disclaimer
In   no event shall Author be liable for any damages whatsoever (including,   without limitation, damages for loss of use, data or profit) arising  out  of the use or inability to use the posting's information even if  Author  has been advised of the possibility of such damage.
Posting
US <> Australia, 225 ms sounds reasonable.  Basically, they're far (physically) apart, and electrical signals take time to cross that distance.
WAAS/WAFS might be a good option.  Much depends on the nature of the application.
Another option might be local servers, if the application allows for some kind of background replication.
Joseph W. Doherty
Disclaimer
Posting
Thanks Joseph  for the respond....I Think you are correct is to far....
