Performance Routing support for EIGRP Parent Routes
metalium2007
Level 3
Level 3
I'm designing the implementation of PfR in my network. I would like to know if my border routers can support EIGRP Parent Routes.
(I've read in the documentation that there is a CSCsk39768 - PfR-EIGRP integration for future releases. Where can i get info about CSCsk?)
Met.
7 Replies 7
Joseph W. Doherty
I believe at this time, only static and BGP routing is supported by PfR. Futher believe both EIGRP and OSPF are on the "roadmap" for future implementation.
Yes, indeed that is what CSCsk39768 says. I would like to track CSCsk39768 status? Is there any online tool to do that?
Met.
You can look up the details of the bug from the below bug toolkit
http://tools.cisco.com/Support/BugToolKit/action.do?hdnAction=searchBugs
Arul
*Pls rate if it helps*
Did that before but is an internal bug, not available to check.
Anyway, thank you for your help.
rgds,
Met.
Met,
PfR support for EIGRP was introduced into 15.0(1)M.
Best Regards,
Steve Lyons - Cisco
Hi Steve,
Please call Virtolia
