2610 Ethernet port speed
greggsmithjr
I have a 2610 router.  How can I tell if the built-in ethernet port is only a 10BASE-T or if it's a 10/100 port?  If it's only 10BASE-T, can I upgrade it to 10/100?
Gregg
206-795-0597
26 Replies 26
paolo bevilacqua
It's 10, and cannot be upgraded. The router would not cope with more traffic anyway.
Joseph W. Doherty
Disclaimer
The    Author of this posting offers the information contained within this    posting without consideration and with the reader's understanding that    there's no implied or expressed suitability or fitness for any  purpose.   Information provided is for informational purposes only and  should not   be construed as rendering professional advice of any kind.  Usage of  this  posting's information is solely at reader's own risk.
Liability Disclaimer
In    no event shall Author be liable for any damages whatsoever  (including,   without limitation, damages for loss of use, data or  profit) arising  out  of the use or inability to use the posting's  information even if  Author  has been advised of the possibility of such  damage.
Posting
According to Table 1 in: http://www.cisco.com/en/US/prod/collateral/routers/ps259/prod_qas0900aecd802a9470_ps5854_Products_Q_and_A_Item.html, the 16 FastEthernet port is supported in 2600 series.  But as Paolo noted, a 2610 can't really can't cope with 100 Mbps.
fb_webuser
Level 6
Level 6
If it is return Fast ethernet it must be 100 Base -t
Posted by WebUser Srinivasa Reddy
greggsmithjr
Thank you Paolo, Joseph, and Srinivasa.
  1. Is there a command I can issue on the 2610 router (e.g. a SHOW command?) that will tell me what kind of ports I have -- 10Base-t, 10/100, etc. and if they are half or full duplex?
  2. You say it cannot handle 100mbps traffic -- It won't have 100mbps of traffic, but can it handle 50 or 70mbps (that's what I expect)?  What's the bottle neck?
  3. If this router won't handle 50-70mbps of traffic, what router should I replace this with?  Would a 2620 router be able to handle the traffic?  I believe it has a 10/100 port standard.
  4. The 2610 has 2 WIC ports ... can I install 10/100 cards in these slots?  Which card would I get and can I assign them such one is the WAN side and the other is the LAN side?
We are a small ISP, local ISP and this handle pure internet traffice.
Gregg Smith
206-795-0597
You can use show interface or read a data sheet to confirm.
What I meant to say, is that a 14 yrs old router will not handle 10 Mbps, let alone more than that.
You should look at a 1941 ISR G2 or better for that. Older models are obsolete and useless.
Disclaimer
Posting
The bottleneck is the performance of the 2610's CPU is not sufficient for 100 Mbps.  I've attached a Cisco performance sheet for various models.  Take the Fast/CEF Switching performance and divide by 4 to provide a rough estimate of how much bandwidth the router might handle.
for .1 the command will be show interface capabilities
greggsmithjr
Thanks again Paolo and Joseph,
I looked at the performance sheet ... so are you saying that if I have a 100mpbs connection to the internet, then I need the Fast/CEF to be 400Mbps (you said divide by 4)?  I don't see many that can do this.  Even the 1941 ISR G2 is rated at 153.08 -- so can it only handle 38Mbps of throughput?  Am I reading this chart correctly?
I ran a SHOW INTER and only get the following -- nothing about port speed or type of duplex :-(  Any other commands that might work?
Ethernet0/0 is up, line protocol is up
  Hardware is AmdP2, address is 0004.dda9.3720 (bia 0004.dda9.3720)
  Description: Local LAN
  Internet address is 216.127.38.238/30
  MTU 1500 bytes, BW 10000 Kbit, DLY 1000 usec,
     reliability 247/255, txload 2/255, rxload 19/255
  Keepalive set (10 sec)
  Last input 00:00:00, output 00:00:00, output hang never
  Input queue: 0/75/2252/0 (size/max/drops/flushes); Total output drops: 0
  Queueing strategy: fifo
  Output queue :0/40 (size/max)
  5 minute input rate 754000 bits/sec, 92 packets/sec
  5 minute output rate 105000 bits/sec, 75 packets/sec
     3244218 packets input, 3565705456 bytes, 0 no buffer
     Received 671 broadcasts, 0 runts, 0 giants, 0 throttles
     205712 input errors, 205707 CRC, 0 frame, 0 overrun, 0 ignored
     2648867 packets output, 368901846 bytes, 0 underruns
     64 output errors, 0 collisions, 3 interface resets
     64 lost carrier, 0 no carrier
Thanks again.
I want to make sure I'm looking at this correctly and get the network sized properly ... so sorry for all the Q's.
-Gregg
greggsmithjr
The new circuit coming in is fiber --- it's 30megs now but can be turned up to 100megs.  I don't see going over 50megs anytime in the near future.
I had another idea. I have a Cisco WS-C3550-24-PWR Swich connected to the 2610 router ... can I simple remove the router and use just this switch?  Is it capable of this?
Gregg
It is capable of handling the circuit, but chances are you will need the features of a true router, not a first generation layer 3 switch.
greggsmithjr
Thanks Paolo -- I hear ya!
I still want to make sure I get the right router ... Joseph sent the Cisco Performance Sheet and he said that I need to look at the Fast/CEF Mbps data and divide by 4 for tru throughput.   So I assume I need a router that's capable of 400Mbps minimum ... correct?  I don't see many that can do this.  Even the 1941 ISR G2 is rated at 153.08Mbps -- so can it only handle 38Mbps of throughput (divide by 4?)?  Am I reading this chart correctly?
Thanks again.
-Gregg
Theres your bandwidth.....You should consider logging on the router and doing a clear counters, I notice a fair number of CRC errors. do a clear counters and then a show interface about an hour after that....there could be some underlying issues.
For the record, Paolos recomendation is pretty rock solid, In fact I would be tempted to go up a notch on the router.
Don't use a switch, you need a router.
Thanks.
What router would your recommend?   I only need 1 10/100 WAN port and 1 10/100 LAN port ... and I need to be able to handle up to about 70mbps  ... possibly 100mbps over the long run of throughput.  I'm thinking something on Ebay ... I have a tight budget, so whatever will work for the least money :-)
Gregg
Based on that swag, MAYBE a high end 2800.... If you go to the cisco web page select routers  and branch there is some "hint' at the performance numbers for each model. Given what you have stated, the 29xx is listed at topping out at 75Mb....that pushes you into 3900 terrritory. You could scout around for an old 7200.....but let the buyer beware.
