2610XM with HWIC-4T
Hitesh Vinzoda
Level 4
Level 4
Hi Guyz,
I have a question regarding compatibility of HWIC-4T with 2610XM routers.. Have anyone ever tried using HWIC-4T(smart serial) with 2610XM routers on both slots adding upto 8 serial interfaces ??
I want to setup the 2610XM router as a FR switch for simulation using HWIC-4T cards ??
Please advice
Hitesh Vinzoda
You asked, and I answered about HWIC, not WIC. These are different things.
Please remember to rate useful posts with the scrollbox below.
5 Replies 5
paolo bevilacqua
Only ISR routers support HWIC cards. 26xx do not.
i m using 2610XM routers with WIC-2T i.e. Smart serial, perfectly fine..
Hitesh Vinzoda
Thanks for your prompt response..
Hitesh Vinzoda
Leo Laohoo
Paolo's right. HWIC will physically not fit into a 2600 router. If you look at the assembly, the HWIC has three rows of pins while the 2600 (and WICs) has a row of two.
