2612 Router
rmurdoch
Does anyone know if I can config dot1q on an Ethernet port on the above router. I'm trying to set up a couple of VLAN's for testing on an old router we have. I've tried several times only to no avail I keep getting this error
Configuring IP routing on a LAN subinterface is only allowed if that
subinterface is already configured as part of an IEEE 802.10 or ISL vLAN.
2600#sh ver
IOS (tm) C2600 Software (C2600-I-M), Version 12.0(10), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2000 by cisco Systems, Inc.
Compiled Mon 20-Mar-00 23:30 by phanguye
Image text-base: 0x80008088, data-base: 0x80600628
ROM: System Bootstrap, Version 11.3(2)XA4, RELEASE SOFTWARE (fc1)
2600 uptime is 1 week, 4 days, 5 hours, 11 minutes
System restarted by reload
System image file is "flash:c2600-i-mz.120-10"
cisco 2612 (MPC860) processor (revision 0x102) with 26624K/6144K bytes of memory
Processor board ID JAD05280PNJ (4199784697)
M860 processor: part number 0, mask 49
Bridging software.
X.25 software, Version 3.0.0.
1 Ethernet/IEEE 802.3 interface(s)
1 Token Ring/IEEE 802.5 interface(s)
2 Serial(sync/async) network interface(s)
32K bytes of non-volatile configuration memory.
8192K bytes of processor board System flash (Read/Write)
Any help would be greatful...thanks
Rob
Hello Rob,
TMBK, you need IOS 12.2(2)T for 802.1Q support on the built-in 10MB Ethernet interface, or 12.1(5)T for the Fast Ethernet interfaces and modules. Check the following links:
802.1Q Encapsulation Support on Cisco 2600/3600 Series Routers
http://www.cisco.com/en/US/partner/products/hw/routers/ps259/prod_bulletin09186a00800921e4.html
Configuring InterVLAN Routing and ISL/802.1Q Trunking on Catalyst 2900XL/3500XL/2940/2950/2970 Series Switches Using an External Router
--> scroll down to ´Table 2´
http://www.cisco.com/warp/public/473/50.shtml#hw
HTH,
GP
