2621XM how many t-1's?
jerry.mcrae
i want to run 6 t-1's on a 2621XM router - do you guys think it will work fine or will i see performance issues. i am going to replace an nm-hdv with an nmhdv-2t1 module along with a two port vwic2mft. one circuit is a PRI, one is a Internet T and the rest are private t's to other remote offices.
thanks in advance
amit-singh
Level 8
Level 8
2621XM can handle upto 8T1's in your single BOX. The fast switch preformace of the 2621XM router is 12.80 Mbps with 25Kpps. I think it should be able to handle 6 T1's in your case and it will work for you.
HTH,Please rate if it does.
-amit singh
amit-singh
Level 8
Level 8
-amit singh
perfect! where can i find information like this?
thanks.
Amit,
do you have any link that states the same.
I have seen that the 2621 runs into high cpu issues during peak utilization with 4 Mbps link.
I would seriously recommend a 2800 for this
Narayan
