2800 series router SHDSL-V2 WIC support confusion
jd205
I am confused as to which of the 2800 series integrated services routers support the SHDSL-V2 WIC (1 port G.shdsl WIC (two or four wire)).
The Data Sheet for the Cisco 2800 Series Integrated Services Routers (http://www.cisco.com/application/pdf/en/us/guest/products/ps5854/c1650/cdccont_0900aecd8016fa68.pdf) at page 15, shows that the 2801 router doesn't support the SHDSL-V2 WIC and the 2811, 2821 and 2851 all support it. This is fine.
But I was reading an article on a V3PN configuration article "Hoot and Holler over V3PN Configuration Example" (http://www.cisco.com/univercd/cc/td/doc/product/access/acs_mod/2800/sw/examples/hhv3pn.pdf) and on page 4 it says that the Branch 1 location in the diagram on the previous page is using a Cisco 2801 router with a WIC SHDSL-V2 WIC.
So my question is, does the Cisco 2801 integrated services router support the SHDSL-V2 WIC?
/Dave
s-doyle
Level 3
Level 3
As per the 2800 integrated service router fact sheet, it clearly says that the 2801 router does not support SHDSL-V2 WIC.
So i guess there must have been a error in the other article on the V3PN configuration.
