2801 - Max Ethernet Speed
snooter
We have a 2801 rotuer in place that hooks up to a metro ethernet link that's obviously dropped off to us via ethernet.  Anyway, the throughput granted to us is 20MB, but for some reason I can't get it to go anything above 11MB at the most.  I've spent a day going through documentation trying to find the fastest speed the 2801 supports and I can't find my answer.  I've seen that the high speed wan cards in this router support up to 45MB, but I'm not using a WAN card, only one of the two built in 10/100 ports.
Anyone able to lend me some information here on what the maximum throughput speed is on a 2801?
Also, there is no traffic shaping in place on our equipment on either end.  It's wide open.
Joseph W. Doherty
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
http://www.cisco.com/web/partners/downloads/765/tools/quickreference/routerperformance.pdf
7 Replies 7
daviddun
Level 3
Level 3
snooter,
Good morning
The 2801 Router is not a small business class router and we have moved your discussion to this area:
https://supportforums.cisco.com/community/netpro/network-infrastructure/routing
I hope you have a great day
paolo bevilacqua
Post config, hide address and password as necessary.
version 12.4
service password-encryption
hostname
boot-start-marker
boot system flash c2801-ipvoicek9-mz.124-15.T8.bin
boot-end-marker
logging buffered 51200 warnings
no logging console!
no aaa new-model
clock timezone Central -6
clock summer-time Central recurring
dot11 syslog
ip cef
no ip domain lookup
voice-card 0
class-map match-any Voip
match ip dscp ef
match ip rtp 16384 16383
class-map match-any Voip-Signaling
match ip dscp cs3
match ip dscp af31
policy-map qos
class Voip
priority percent 50
class Voip-Signaling
bandwidth percent 2
class class-default
fair-queue
interface FastEthernet0/0
no ip address
duplex auto
speed auto
interface FastEthernet0/0.1
encapsulation dot1Q 1 native
ip address 10.10.4.1 255.255.255.0
ip helper-address 10.10.1.5
interface FastEthernet0/0.4
encapsulation dot1Q 4
ip address 172.16.4.254 255.255.255.0
ip helper-address 172.16.1.1
no ip redirects
no ip unreachables
no ip proxy-arp
h323-gateway voip bind srcaddr 172.16.4.254
interface FastEthernet0/0.6
encapsulation dot1Q 6
ip address 10.10.6.1 255.255.255.0
interface FastEthernet0/1
description ISP Metro Ethernet
bandwidth 20480
ip address XX.XX.XX.XX 255.255.255.252
ip flow egress
ip route-cache flow
load-interval 30
speed 100
full-duplex
interface Serial0/3/0
description ISP Failover T1 bandwidth 1536
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
encapsulation frame-relay IETF
frame-relay lmi-type ansi
service-policy output qos
interface Serial0/3/0.16 point-to-point
no ip redirects
no ip unreachables
no ip proxy-arp
snmp trap link-status
frame-relay interface-dlci 16 IETF
class qos
router bgp 65015
no synchronization
bgp log-neighbor-changes
redistribute connected
redistribute static
neighbor XX.XX.XX.XX remote-as 10970
neighbor XX.XX.XX.XX password 7 xxxxxxxxxxxxx
neighbor XX.XX.XX.XX update-source FastEthernet0/1
neighbor XX.XX.XX.XX version 4
neighbor XX.XX.XX.XX weight 30
neighbor XX.XX.XX.XX description ISP T1
neighbor XX.XX.XX.XX update-source Serial0/3/0.16
no auto-summary
ip forward-protocol nd
ip bgp-community new-format
ip flow-cache timeout active 5
ip flow-export source FastEthernet0/1
ip flow-export version 5
ip flow-export destination 10.10.4.14 9996
no ip http server
no ip http secure-server
ip prefix-list isp-in seq 5 deny 0.0.0.0/0 isp 32
map-class frame-relay qos
frame-relay cir 1536000
frame-relay bc 1536000
frame-relay be 1536000
frame-relay mincir 1536000
access-list 101 permit tcp any any eq 5022
access-list 101 permit tcp any any eq 5023
access-list 102 permit tcp any any eq 7333
snmp-server community ia RO
control-plane
voice-port 0/0/0
description SRST
voice-port 0/0/1
description SRST
dial-peer cor custom
dial-peer voice 10 pots
description SRST
destination-pattern 3T
port 0/0/0
dial-peer voice 11 pots
description SRST
port 0/0/1
dial-peer voice 200 voip
destination-pattern 8684
session target ipv4:10.10.1.97
incoming called-number .
codec g711ulaw
no vad
end
Joseph W. Doherty
Disclaimer
Posting
Thank you Joesph.  Exactly what I was looking for.
So, given my running config above, I'm assuming the issue has to be outside of my 2801.  I should easly be able to get 20MB through the 2801.
Check show interfaces for drops and other anomalies.
Also need to know how are you measuring the performance limitation.
Disclaimer
Posting
Keep in mind when you look at the performance charts you often need to allow for duplex (i.e. forwarding in both directions) and you need to allows for services.
A quick test whether this router's performance capabilities is the bottleneck, check CPU load when it hits your 11 Mbps.  If the router isn't near 100%, then router's forwarding capacity likely isn't the culprit.  That doesn't exclude the router itself from being the culprit, which is partially why Paolo is asking for the information he does.
