2811 router can support E1 card
iqbalkhan
I have a 2811 router , this router support E1 card ??.
thanks
biplob
network.king
Level 4
Level 4
If your query was abt the channelised E1 card , then it supports NM-2CE1T1-PRI card.
In case if you require further info , go to the tools option in cisco site and look out for dynamic configuration tool --guest login is fine and you can search for the same.
regards
vanesh k
smothuku
Level 7
Level 7
Hi Biplob ,
The below link gives info about supported cards on 2811 router.
http://www.cisco.com/en/US/products/ps5854/prod_module_install_config_guide09186a00802c9351.html#wp1061244
Hope this helps you.
Satish
clausonna
Level 3
Level 3
I have a few 2821's running the VWIC-1MFT-G703 WIC, which supports E1 circuits. One site is in Ireland and the other is in Germany. I think your best bet is to ask your ISP exactly how they are going to 'deliver' the circuit (framed/unframed, PPP/Frame Relay) and then verify with them which WIC you should buy. But in general, I think a 2811 should be fine.
Relevant info from one of my configs:
controller E1 0/0/0
channel-group 0 unframed
interface Serial0/0/0:0
description Outside Interface
ip address
encapsulation ppp
router#show controllers e1
E1 0/0/0 is up.
Applique type is Channelized E1 - balanced
No alarms detected.
alarm-trigger is not set
Version info Firmware: 20051006, FPGA: 20, spm_count = 0
Framing is UNFRAMED, Line Code is HDB3, Clock Source is Line.
CRC Threshold is 320. Reported from firmware is 320.
Data in current interval (619 seconds elapsed):
0 Line Code Violations, 0 Path Code Violations
0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
Total Data (last 24 hours)
0 Line Code Violations, 0 Path Code Violations,
0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins,
