04-03-2009 10:06 PM - edited 03-04-2019 04:14 AM
Dear All,
2811 router sh tech nm port not working,
plz suggest me.plz find the attachment.
04-09-2009 06:11 PM
The 2811 do not support NM-1E1R or NM-2E. Ensure your Network module will support or not. Romove the Nm module And switch off the router then insert the module. Once you installed the restart the module and configure newly then try.
04-09-2009 06:55 PM
NM "what ?".
You've only sent show config.
Please describe the problem properly.
04-09-2009 07:50 PM
I'll agree with the 2 post before me. What network modules did install? Aside from the NM-1E, I think you also put a NM-4T too.
The link below will tell you what modules you can install into your appliance. Good luck.
http://www.cisco.com/en/US/products/ps5854/products_data_sheets_list.html
