2901 routing issues
nestorq
I have 2901 i cant reach next hop, here is the configurations and pings..
Somebody can help me
Router#sh run
Building configuration...
Current configuration : 1249 bytes
! Last configuration change at 17:39:44 UTC Sat Feb 2 2013
version 15.1
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
no ipv6 cef
ip source-route
ip cef
voice-card 0
license udi pid CISCO2901/K9 sn FTX170280F4
hw-module pvdm 0/0
hw-module pvdm 0/1
redundancy
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
ip address dhcp
duplex auto
speed auto
interface GigabitEthernet0/1
ip address 172.16.2.1 255.255.255.0
duplex auto
speed auto
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 192.168.1.1
control-plane
mgcp profile default
gatekeeper
shutdown
line con 0
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
login
transport input all
scheduler allocate 20000 1000
end
Router#
Ping from Router to PC
Router#ping 172.16.2.10
Sending 5, 100-byte ICMP Echos to 172.16.2.10, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/1 ms
Router#
Router#sh ip route
Codes: L - local, C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2
       i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, * - candidate default, U - per-user static route
       o - ODR, P - periodic downloaded static route, H - NHRP, l - LISP
       + - replicated route, % - next hop override
Gateway of last resort is 192.168.1.1 to network 0.0.0.0
S*    0.0.0.0/0 [1/0] via 192.168.1.1
      172.16.0.0/16 is variably subnetted, 2 subnets, 2 masks
C        172.16.2.0/24 is directly connected, GigabitEthernet0/1
L        172.16.2.1/32 is directly connected, GigabitEthernet0/1
      192.168.1.0/24 is variably subnetted, 2 subnets, 2 masks
C        192.168.1.0/24 is directly connected, GigabitEthernet0/0
L        192.168.1.10/32 is directly connected, GigabitEthernet0/0
Router#
Router#
Ping from PC to router interface WAN
Pinging 192.168.1.10 with 32 bytes of data:
Reply from 192.168.1.10: bytes=32 time<1ms TTL=255
Ping from PC to Router nexthop
Pinging 192.168.1.1 with 32 bytes of data:
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Ping from router to nexthop
Router#ping 192.168.1.1
Sending 5, 100-byte ICMP Echos to 192.168.1.1, timeout is 2 seconds:
Router#
Nestor,
at no point have you explicitly stated that 192.168.1.1 has a route to 172.16.2.0/24; your last statement could be interpreted to mean either :
a) "192.168.1.1 gives out an address to the 2901 via DHCP and 192.168.1.1 also has a route to 172.16.2.0/24 that goes via the 2901. It knows how to get to that network but it still doesn't work!" [ie "he" is referring to 192.168.1.1]
or
b) "192.168.1.1 gives out an address to the 2901 via DHCP but 192.168.1.1 does not have a route to the 172.16.2.0/24 network. I just expect it to work because the 2901 knows how to get to that network". [ie "he" is referring to the 2901]
If statement a) is true then it sounds more like an ACL type problem, most likely on 192.168.1.1.
If statement b) is true then it will not "just work". 192.168.1.1 *MUST* know how to get to 172.16.2.0/24 in order for it to correctly reply to traffic it receives. It could be as simple as setting a static default route via 192.168.1.10 (but that doesn't seem very sensible), it could be a static route that lists 192.168.1.10 as the correct next hop to get to 172.16.2.0/24 or you could setup a routing protocol so that 192.168.1.10 can advertise a route to 172.16.2.0/24 that 192.168.1.1 can then learn. In any event it must be able to send reply traffic back to 192.168.1.10 so that the 2901 can then forward it back to the 172.16.2.0/24 network.
Please can you confirm whether or not a route to 172.16.2.0/24 exists in the 192.168.1.1 machine ?
Cheers,
Pat.
6 Replies 6
patrickherborn
Nestor,
Check that the machine at 192.168.1.1 has a route to 172.16.2.0/24 via 192.168.1.10.
Cheers,
Pat.
i dont care, becasue i try to reach 192.168.1.1 from 172.16.2.0 via 192.168.1.10..
just make sure that 192.168.1.1 has a route for the 172.16.2.0/24 network or use NAT.
Alain
the 192.168.1.1 give to the 2901 DHCP and he is routing 172.16.2.0..
Nestor,
or
Cheers,
Pat.
Hi the answer is some mistake with access list, i create NAT and the access list.. here is the configurations
thanks everybody
Router#sh run
Feb  3 01:16:14.771: %SYS-5-CONFIG_I: Configured from console by console
Current configuration : 1569 bytes
! Last configuration change at 01:16:14 UTC Sun Feb 3 2013
! NVRAM config last updated at 01:13:09 UTC Sun Feb 3 2013
version 15.1
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
no ipv6 cef
ip source-route
ip cef
voice-card 0
hw-module pvdm 0/0
hw-module pvdm 0/1
redundancy
no ip address
shutdown
ip address dhcp
ip nat outside
ip virtual-reassembly in
duplex auto
speed auto
ip nat inside
duplex auto
speed auto
no ip http server
ip nat inside source list 101 interface GigabitEthernet0/0 overload
access-list 101 permit ip 172.16.2.0 0.0.0.255 any
control-plane
gatekeeper
shutdown
line con 0
line aux 0
line 2
no exec
transport input all
stopbits 1
line vty 0 4
login
transport input all
end
