1941w: AP cant ping 2nd router/host but router can
Techy0x90
Hello all,
From the router I can ping the 2nd router, all its host and all of the 1941w interfaces.
From the 1941w AP i cannot reach the 2nd router or any of its host, but I can reach the interface that is connected to the 2nd router but only one side of it.
Attached are both my router and ap configs. At the moment I am just trying to reach the 2nd router and its host so I can update the AP IOS image but cannot reach the tftp server.
5 Replies 5
Abzal
Level 7
Level 7
From your explanation it's hard to understand. Post here network diagram. And check your routing on both routers.
Hope it will help.
Best regards,
Abzal
Best regards,
Abzal
I can ping the TFTP server from the router, but when i telnet into the AP and try i cant reach it. The farthest i cant get is 192.168.1.103 (giabitethernet 0/0)
put a static route for the 192.168.2.0/24 network on the Linksys pointing towards the 1941 router.
Alain
from the TFTP server i can ping the AP BVI 1 interface 192.168.2.2 but i still cannot ping the TFTP server from the access point. When i do a trace route for 192.168.1.1 or 192.168.148 i get nothing. If i traceroute to 192.168.1.103 i have one hop. From 192.168.2.2 to 192.168.2.1. I added the route as suggested but it did not help.
i figured it out. i had to enable "routing dynamic" for the ap gigabit ethernet0 interface.
