Bookmark
Subscribe
2143
2901 VWIC card issue
jlmickens
I added a VWIC2 1MFT-T1/E1 card to my 2901 router.  There were two in it already, and I need to add a 3rd circuit.  After installing the card, the boot process sees the new card, but once it is completely booted, the new card is nowhere to be found.  I've swapped cards around to no avail.  The new card works fine in one of the slots that had the existing cards in it.
From the boot sequence, I can see:
Smart Init is enabled
smart init is sizing iomem
                 TYPE      MEMORY_REQ
          HWIC Slot 0      0x00200000
          HWIC Slot 1      0x00200000
          HWIC Slot 2      0x00200000 <-- New card - same when I had it in Slot 3
    Onboard devices &
         buffer pools      0x0228F000
               TOTAL:      0x0288F000
Rounded IOMEM up to: 44Mb.
Using 8 percent iomem. [44Mb/512Mb]
As well as:
Cisco CISCO2901/K9 (revision 1.0) with 479232K/45056K bytes of memory.
Processor board ID FTX134981AF
2 Gigabit Ethernet interfaces
3 Channelized (E1 or T1)/PRI ports <-- 3 total cards
1 Virtual Private Network (VPN) Module
DRAM configuration is 64 bits wide with parity enabled.
255K bytes of non-volatile configuration memory.
254464K bytes of ATA System CompactFlash 0 (Read/Write)
But once it is up, I do a show ver or show hardware, and see the following:
2 Serial interfaces
2 Channelized T1/PRI ports
1 Channelized (E1 or T1)/PRI port
Is this a config issue?  I'm going to start going over it with a fine tooth comb, but could use some direction.
Smart Init is enasmart init is sizing iomem                 TYPE      MEMORY_REQ          HWIC Slot 0      0x00200000          HWIC Slot 1      0x00200000          HWIC Slot 2      0x00200000    Onboard devices &         buffer pools      0x0228F000 -----------------------------------------------               TOTAL:      0x0288F000
Rounded IOMEM up to: 44Mb.Using 8 percent iomem. [44Mb/512Mb]
Jon Marshall
Have you configured the card with the "card type" command ? If not then you need to specify it -
http://www.cisco.com/en/US/customer/docs/ios/interface/command/reference/ir_c1.html#wp1012287
Jon
Jon Marshall
Jon
No - that looks like the problem.  I hadn't pored through the config yet to see what was done for the others, and when I did a show config it even gave me a comment stating that I need to do that - lol.  Just goes to show you to check the config first...  gotta love inheriting things other people set up. :-P
