2921 router interface shows up and up but unable to PING peer
STEVE FOWLER
I have a 2921 router directly connected to an Ethernet MPLS network, one of about 10 location all configured the same. This is a new install and has been tested by the LEC to be good however, even thought the interface below indicates to be up/up we are unable to PING the peer IP address or establish a BGP session. I have chaned the speed/duplex to every combination possible and tried makeing the VLAN ID 16 native but nothing works.
Does anyone know where I might start looking for the problem?
interface GigabitEthernet0/2
description descript Circuit ID:
bandwidth 5120
ip vrf forwarding main
no ip address
duplex auto
speed auto
no keepalive
no cdp enable
end
MPLS#sh run int g0/2.16
Building configuration...
Current configuration : 240 bytes
interface GigabitEthernet0/2.16
description
bandwidth 5120
encapsulation dot1Q 16
ip address 10.70.0.149 255.255.255.252
no ip redirects
no ip proxy-arp
no cdp enable
end
MPLS#sh int g0/2
GigabitEthernet0/2 is up, line protocol is up
  Hardware is CN Gigabit Ethernet, address is c84c.7537.a592 (bia c84c.7537.a592)
  Description: descript Circuit ID:
  MTU 1500 bytes, BW 5120 Kbit/sec, DLY 100 usec,
  Encapsulation 802.1Q Virtual LAN, Vlan ID  1., loopback not set
  Keepalive not set
  Full-duplex, 100Mb/s, media type is RJ45
  output flow-control is XON, input flow-control is XON
  Last input 00:00:03, output 00:00:03, output hang never
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
     1058 packets input, 69805 bytes, 0 no buffer
     Received 6 broadcasts, 0 runts, 0 giants, 0 throttles
     4 input errors, 2 CRC, 0 frame, 0 overrun, 0 ignored
     0 watchdog, 2 multicast, 0 pause input
     1054 packets output, 69405 bytes, 0 underruns
     0 output errors, 0 collisions, 6 interface resets
     2 unknown protocol drops
     9 lost carrier, 0 no carrier, 0 pause output
MPLS#sh  int g0/2.16
GigabitEthernet0/2.16 is up, line protocol is up
  Description: SPECTRUM_IF_ALIAS_145f500a
  Internet address is 10.70.0.149/30
  MTU 1500 bytes, BW 5120 Kbit/sec, DLY 1000 usec,
  Encapsulation 802.1Q Virtual LAN, Vlan ID  16.
  Keepalive set (10 sec)
MPLS#sh ip bgp vpnv4 vrf main summ
BGP router identifier 199.160.108.231, local AS number 65007
BGP table version is 178, main routing table version 178
145 network entries using 20880 bytes of memory
285 path entries using 14820 bytes of memory
56/25 BGP path/bestpath attribute entries using 7392 bytes of memory
16 BGP AS-PATH entries using 560 bytes of memory
2 BGP community entries using 48 bytes of memory
10 BGP extended community entries using 1026 bytes of memory
0 BGP route-map cache entries using 0 bytes of memory
0 BGP filter-list cache entries using 0 bytes of memory
BGP using 44726 total bytes of memory
139 received paths for inbound soft reconfiguration
BGP activity 351/192 prefixes, 704/390 paths, scan interval 60 secs
Neighbor        V           AS MsgRcvd MsgSent   TblVer  InQ OutQ Up/Down  State/PfxRcd
10.70.0.150     4        21302       0       0        1    0    0 never    Active
MPLS#sh run | b router bgp
router bgp 65007
bgp router-id 199.160.108.231
bgp router-id vrf auto-assign
bgp log-neighbor-changes
address-family ipv4
  no synchronization
  network 10.34.3.0 mask 255.255.255.0
  network 10.34.17.0 mask 255.255.255.0
  network 10.34.24.0 mask 255.255.255.0
  network 10.34.90.0 mask 255.255.255.0
  network 10.34.100.0 mask 255.255.255.0
  network 10.34.125.0 mask 255.255.255.0
  no auto-summary
exit-address-family
  address-family ipv4 vrf main
  no synchronization
  network 10.70.0.36 mask 255.255.255.252
  network 199.160.108.231 mask 255.255.255.255
  redistribute static
  neighbor 10.70.0.37 remote-as 1803
  neighbor 10.70.0.37 activate
  neighbor 10.70.0.37 soft-reconfiguration inbound
  neighbor 10.70.0.150 remote-as 21302
  neighbor 10.70.0.150 local-as 64608 no-prepend replace-as
  neighbor 10.70.0.150 activate
exit-address-family
16 Replies 16
the problem was stated as the folowing
"I too have the same issue and have tried fiddling with speed and duplex. Have also plugged a laptop into both the provider handoff and separately the router wan port and am able to ping the laptop from router and provider next hop successfully. I plug the router into the handoff and no ping / incomplete arp. I have tried configuring different router ports with same result. Have tried loopback cable with same result.  Provider insists problem is our equipment. Any suggestions / ideas?"
I too have same issue, was this resolved and if so how.
So you are particularly interested in the post by tbarkhaus in June 2018. This might or might not be the same as the issues posted in July 2013 and Feb 2016. I hope that tbarkhaus is still participating in the forum and will respond about whether the issue was solved.
Rick
Rick
