Drops in LLQ with compress header ip rtp
patcbr600
I have a cisco 7200 with 12.3(12) with LLQ configured and compress header ip rtp in the class,(ppp link)
policy-map QPM_GC2WAN
description gestao congstao nos int WAN core com CRTP
class QPM_FGCVoice
priority 370
class QPM_FGCBusi2
bandwidth percent 50
queue-limit 128
class class-default
fair-queue
From the show policy-map I see that the router discard all the packets for the class QPM_GC2WAN
and increments erros on the rtp statistis, causing bad quality in the voice traffic, if I remove de compress header ip rtp
from the policy the problem disapear.
WFQ: dropping a packet from the priority queue 39
Thua any one know if is some problem in the configs or some bus in the IOS
IOS: c7200-js-mz.123-12.bin
Chris Deren
Did you configure header compression on both ends of the network? You need it on both routers!
Chris
I have configured on both sides, the same policy-map on the two routers and the output is:
(total drops/bytes drops) 1893/112310
with an 30 second offered rate 60000 bps when the limit is 370k.
