3640 vs. 3640A
daniel.kline
What are the differences between the 3640 and 3640A routers? How can I tell which model I have?
Tsasbrink
From what i understood they ran out of part producing 3640's the parts they used where replaced bij some others witch needed some code changes in the software.
if you have a 3640a it should be clearly stated on the model sticker on the bottem of the unit.
Thanks. I have seen references to the 3640A in Cisco documentation, but have never actually seen one; at least I don't think I have.
I was recently reviewing the dcoumentation for the NM-HDA, stating that this network module works in the 3640A router. But the documentation makes no reference as to whether it works in the 3640.
dk
The documentation witch i have seen shows the nm-hda usable on the 3640/A witch is prably supposed to mean both models.
