3745 VWIC2 Configuration help
justin.allen
I cant figure this out to save my life. Can somebod take a peek at this and tell me if this is right. I cant get the controllers to come up/up they are always up/down. I put them on a 2821 and they come right up. I do show them up/down but they never come up. I use the same config on the 2821, with differnt interface names of course, and it goes to up/up. Any help would be much appreciated.
card type t1 0 0
card type t1 0 1
no network-clock-participate wic 0
no network-clock-participate wic 1
no network-clock-participate wic 2
controller T1 0/0
framing esf
linecode b8zs
channel-group 0 timeslots 1-24
controller T1 0/1
framing esf
clock source internal
linecode b8zs
controller T1 0/2
framing esf
linecode b8zs
controller T1 0/3
framing esf
linecode b8zs
controller T1 0/4
framing esf
linecode b8zs
interface Serial0/0:0
no ip address
encapsulation ppp
no fair-queue
ppp chap hostname www
ppp multilink
ppp multilink group 1
interface Serial0/1:0
no ip address
encapsulation ppp
no fair-queue
ppp multilink
interface Serial0/2:0
no ip address
encapsulation ppp
no fair-queue
ppp multilink
interface Serial0/3:0
bandwidth 1536
no ip address
encapsulation ppp
no fair-queue
ppp multilink
interface Multilink1
ip address x.x.x.x x.x.x.x
ip wccp 62 redirect in
ip nbar protocol-discovery
ip route-cache flow
load-interval 30
ppp multilink
ppp multilink links minimum 1
ppp multilink fragment disable
service-policy output QoS-Policy-Trust
Serial0/0:0 unassigned YES manual up down
Serial0/1:0 unassigned YES manual up down
Serial0/2:0 unassigned YES manual up down
Serial0/3:0 unassigned YES manual up down
Serial0/4:0 unassigned YES manual down down
Version c3745-spservicesk9-mz.124-9.T6.bin
paolo bevilacqua
Controllers are can be only up or down.
Usually down means circuit failure.
Check their state with "show controllers T1".
Unrelated: you want network-clock-participate and -select to avoid slip errors.
So why would they come up on the 2821 and not the 3745 with the same config?
Send "show controllers T1" as taken from both routers and start reasoning from there.
