Easy serial interface question!
darkbeatzz
Hi All
whats up gold picked up my serial inteface on my internet router as being 1.54mbs.
this is not the case, its only 1mb so the graphs are inacurate.
when I do a sh int it says bw is 1.54mbs.
my question is where is that being picked up from?
#sh int serial 0
Serial0 is up, line protocol is up
Hardware is PowerQUICC Serial
Internet address is 1.2.3.4/30
MTU 1500 bytes, BW 1544 Kbit, DLY 20000 usec,
reliability 255/255, txload 19/255, rxload 119/255
Encapsulation HDLC, loopback not set
Keepalive set (10 sec)
Last input 00:00:00, output 00:00:00, output hang never
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 180389
Queueing strategy: fifo
Output queue :0/40 (size/max)
5 minute input rate 724000 bits/sec, 92 packets/sec
5 minute output rate 118000 bits/sec, 64 packets/sec
76684388 packets input, 2897637249 bytes, 0 no buffer
Received 173948 broadcasts, 0 runts, 2 giants, 0 throttles
307 input errors, 63 CRC, 242 frame, 0 overrun, 0 ignored, 2 abort
79636170 packets output, 3021991121 bytes, 0 underruns
0 output errors, 0 collisions, 1 interface resets
0 carrier transitions
DCD=up DSR=up DTR=up RTS=up CTS=up
Edison Ortiz
Default value assigned to T1 serial interfaces. T1 bandwidth = 1.544Mbps
If you want to change it, you can use the bandwidth command under the interface.
HTH,
__
Edison.
Edison Ortiz
HTH,
__
Edison.
