3825 Router Voice Support ?
Rajan R
Hey Guys,
We have the below. Does this support Voice commands ? Or do we need a change of the router itself ? Or any licensing ? Please suggest
C3825-ADVENTERPRISEK9-M, Version 12.4(24)T8
VR
Hello Varadarajan,
First of all you require PVDM installed on the Router.
check this with the command - show inventory - which will provide you with all the inventory installed on that router both pre-installed and modules installed after purchase.
Kindly find the link below which will help you in determining whether your Router will support Voice and if yes; and you need to configure CME on that Router, which version will be supported by 3825.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/requirements/guide/33matrix.htm
If you just need to configure MGCP / PRI, etc. on the Router, you will need to go through this Compatiblity Matrix for CUCM.
http://www.cisco.com/en/US/docs/voice_ip_comm/uc_system/unified/communications/system/versions/CCMtrix.html
For either of the Options better Upgrade your IOS to 15.1(4)M.
For CME the version supported is 8.6 & IOS Compatible for CME on 3825 is 15.1(4)M
For IOS image software that you need to put on 3825 to support Voice - you can browse the Feature Navigator / Software Image Comparison Tool - It can be Advanced IP Services / Advanced Enterprise Services both support Voice Commands
http://tools.cisco.com/ITDIT/CFN/
Hope this helps.
Thanks & Regards,
Venkitesh
5 Replies 5
Subeh Sharma
Hi VR,
What is it that you plan to run on the router? AFAIK you should be to run anything on this release as far you've supported voice modules in the router. You can check the features available on any release by going here:
http://tools.cisco.com/ITDIT/CFN/jsp/SearchBySoftware.jsp
Subeh
We are trying to run SRST on this. Here is the show inventory
Router#sh inv
NAME: "3825 chassis", DESCR: "3825 chassis"
PID: CISCO3825         , VID: V05 , SN: XXXXXYW
NAME: "One-Port Fast Ethernet High Speed WAN Interface Card on Slot 0 SubSlot 0", DESCR: "One-Port Fast Ethernet High Speed WAN Interface Card"
PID: HWIC-1FE          , VID: V01 , SN: XXXXQ7W
VR
Hello Varadarajan,
In your show inventory, there is no PVDM seen. Can you please paste the complete output of show inventory?
Thanks & Regards,
Venkitesh
Hello Varadarajan,
Hope this helps.
Thanks & Regards,
Venkitesh
Hi Venkitesh
Thanks a lot. This answers everything.
It is the full sh inv shared by the client actually.
Varadarajan.R
