3845 configuring E1
luis.elvira
I have to configure a router 3845 with one NM-HDV2-2T1/E1 and two PVDM2-64. I have typed the following commands:
(router-config)# card type e1 1 1
(router-config)# controller e1 1/0
(config-controller)# pri-group timeslots 1-31
And the router shows the following message in console:
% Not enough DSP resources available to configure pri-group on controller E1 1/0
% The remaining dsp resources are enough for 0 time slots.
% For current codec complexity, 2 extra dsp(s) are required to create this voice port.
Does anyone know what can I do? The only solution is to add more DSPs?
Thanks in advance and best regards.
Luis Elvira
You will need to configure dspfarm under the appropriate voice-card for DSP sharing.
Configuration of the dspfarm command enters DSP resources into a DSP resource pool. Those DSP resources are then available to process voice traffic on a different network module or voice/WAN interface card (VWIC).
voice-card 0
dspfarm
Try configuring the pri-group one you have enabled dsp resource sharing as above.
Allan.
graemeporter
Hi Luis,
If you have 128 DSP channels, and only 30 timeslots to be configured, you should have plenty of DSP resources available.
I would guess that you've got a lot of analog ports (FXS, FXO, or E&M), which use 1 DSP channel each - or maybe you have a DSP Farm set up for conferencing on the router, and you've just allocated all the DSP resources already.
Could you post your configuration here so that I can have a look through it?
Kind regards
Graeme
BETAR01#sh run
Building configuration...
Current configuration : 2659 bytes
version 12.3
hostname BETAR01
boot-start-marker
boot-end-marker
card type e1 1 1
logging buffered 100000 informational
enable password cisco
no network-clock-participate slot 1
no aaa new-model
ip subnet-zero
ip cef
no ip domain lookup
ip domain name yourdomain.com
isdn switch-type primary-qsig
isdn voice-call-failure 0
voice-card 0
no dspfarm
voice-card 1
no dspfarm
voice service voip
fax protocol t38 ls-redundancy 0 hs-redundancy 0 fallback cisco
h323
voice class codec 1
codec preference 2 g729r8
voice translation-rule 1
rule 1 reject /^.*/
voice translation-profile call_block_profile
translate calling 1
username cisco password 0 cisco
controller E1 1/0
framing NO-CRC4
description ENLACE Q.SIG
controller E1 1/1
interface Loopback0
description Interface IP VoIP
ip address 172.27.127.2 255.255.255.255
no ip redirects
no ip proxy-arp
h323-gateway voip interface
h323-gateway voip id MAAgk1 ipaddr 172.26.0.41 1719
h323-gateway voip h323-id BETAR01@repsol.com
h323-gateway voip tech-prefix 1#
h323-gateway voip bind srcaddr 172.27.127.2
interface GigabitEthernet0/0
ip address 172.27.88.9 255.255.252.0
no ip redirects
no ip proxy-arp
duplex auto
speed auto
media-type rj45
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
media-type rj45
router eigrp 1
network 172.27.0.0
auto-summary
no eigrp log-neighbor-changes
ip classless
no ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
control-plane
dial-peer cor custom
dial-peer voice 10 pots
call-block translation-profile incoming call_block_profile
call-block disconnect-cause incoming call-reject
incoming called-number 634[0,2]T
direct-inward-dial
dial-peer voice 85 pots
incoming called-number .
direct-inward-dial
dial-peer voice 100 voip
destination-pattern 6T
voice-class codec 1
session target ras
dtmf-relay h245-alphanumeric
dial-peer voice 200 voip
voice-class codec 1
gateway
timer receive-rtp 1200
line con 0
login local
stopbits 1
line aux 0
stopbits 1
line vty 0 4
exec-timeout 100 0
privilege level 15
login local
transport input telnet ssh
escape-character 18
line vty 5 15
exec-timeout 100 0
privilege level 15
login local
escape-character 18
scheduler allocate 20000 1000
end
BETAR01#
voice-card 0
dspfarm
Allan.
