QoS rewrite on ethercahnnel
mats.brynolf
I'm trying to rewrite all traffic to 0 coming in on a etherchannel. This is how the config looks like.
When I do RSPAN and capture traffic for one of these VLANs I can still see DSCP flags set to something other then 0.
class-map match-all rewrite
match access-group name rewrite-dscp
policy-map rewrite
class rewrite
set dscp default
ip access-list standard rewrite-dscp
permit any
interface GigabitEthernet2/35
switchport
switchport trunk allowed vlan 101-179,260-267,269-275,685,686,3601
switchport mode trunk
no ip address
wrr-queue cos-map 1 7 1
wrr-queue cos-map 1 8 4
wrr-queue cos-map 2 2 2
wrr-queue cos-map 3 1 6
wrr-queue cos-map 3 2 7
wrr-queue cos-map 3 8 3
flowcontrol send off
no cdp enable
channel-group 3 mode active
end
interface GigabitEthernet2/36
description ok7-dr1 <-> PP2 Admin
switchport
no ip address
no cdp enable
end
interface Port-channel3
switchport
no ip address
service-policy input rewrite
end
I can't set the service policy command directly on the physical interfaces so that's why its not there.
router(config-if)#service-policy input rewrite
Policy can not be installed because interface GigabitEthernet2/35 is a member of Port-channel
MQC features are not supported for this interface
allan.thomas
Level 8
Level 8
You should configure the port-channel and physical ports with the command 'mls qos vlan-based', and then configure or apply the service-policy rewrite on each of the trunked vlan interfaces (SVIs) as shown below:-
interface port-channel 3
mls qos vlan-based
mls qos vlan-based
mls qos vlan-based
interface vlan 101
interface vlan 179
Allan.
allan.thomas
Level 8
Level 8
mls qos vlan-based
mls qos vlan-based
mls qos vlan-based
interface vlan 101
interface vlan 179
Allan.
